I noticed that the board is slow and the CPU freq is 300000 - Beaglebone Black A5B
Linux arm 3.8.13-bone32 #1 SMP Fri Dec 13 20:05:25 UTC 2013 armv7l armv7l armv7l GNU/Linux
root@arm:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
300000
I know that powering from USB the board will slow down to 300000 MHz but the board is powered from +5 V with a 5Amps power supply
I even boot only from power supply and attach the usb cable after boot sequence (monitoring LED)
Any idea how to switch to high freq ? I also have problems with the USB host - I presume that it is also related to wrong detection of primary power supply
Change the cpu governor to “performance” and you will see difference
I know
But I want to be done automatically at start-up.
Because of poor power management I also have some USB problems
I will post later.
Now I look at differences between Angstrom and Ubuntu.
Angstrom does a far better job with power management and USB devices but does not have some devices files for USB G3 modem and RS 232/USB adapters I must use.
I know
/etc/default/cpufrequtils
https://wiki.debian.org/HowTo/CpuFrequencyScaling
I will post later.
Uh, so why don't you post the details now?
must use.
I just wanted to better document the problems.
Some of them:
If I put USB modem Huawei 3772 direct into the USB connector it flashes and then the power is cut off
If I put a USB hub between the same, but if I put another device into the hub everything is OK and I manage to work with the modem
I will put a list and screen captures wit dmesg later
Some of them:
Is the device powered by USB or the 5volt barrel connector? (what rating)
If that fixes it, then your USB modem is crap, taking way too much
current on startup..
+5 V barrel by a lab power supply 5V/5Amps
the current is 500 mA and the modem works perfect in Angstrom
Well they share the "same" patchset (minus 1-2 distro related
patches).. So you have the Angstrom .config (1) and mine (2)
1: https://github.com/beagleboard/kernel/blob/3.8/configs/beaglebone
2: https://github.com/RobertCNelson/linux-dev/blob/am33x-v3.8/patches/defconfig
Care to bisect/debug?
