Hi I want to blink my led, do a serial communication, update my display at the same time in beagleboard xm.(multitasking).
I am using Sitara SDK, I havent got previous experience with using ccsv5 or Sitara. Is it possible to accomplish this task?
I am using the u-boot and kernel provided with the latest sitara. How to do multitasking thereafter? Should I use Qt or something? Or could you suggest me anything else?
Also how to do debugging?
Regards
Badri Narayanan@nithin <badri89@gmail.com> [12-10-03 07:12]:
me anything else?
Regards
Hi Badri,
simplest attempt would be to create an application for each task (UNIX
way: On eapplication for a certain task) and do communication between
the applaications via rpc/pipes or such.
If you want one application only use fork/exec to create concurrent
tasks.
The multitasking itsself is handled by the linux kernel (scheduling).
HTH!
Best regards,
mcc
Hi meino,
Thanks for your quick reply.
What I have previously attempted is I created executable of qt, and I made a script for autologin and autostart that application.
That means Is it like I can use RTSC provided from ti?
Could you show me any example projects or something implemented like this?
Thank you once again
badri narayanan <badri89@gmail.com> [12-10-03 07:36]:
Hi meino,
> at
> or
> do
> suggest
> > me anything else?
> > Regards
> Hi Badri,
> tasks.
> HTH!
> Best regards,
> mcc
Badri Narayanan@Nithin
Hi Badri,
no, sorry, I cant give you examples here.
the fork()/exec() system call is part of any UNIX system and base of
UNIX system programming. It is included in the C-library. For that
you dont need any other library.
RTSC is a real time approach. This something totally different.
Real time programming means that a certain task has been finished
in a predefined time.
It looks like you are comparing apples with houses (no punt
intended!).
For UNIX programming and fork()/exec() look here:
http://www.osix.net/modules/article/?id=641
Be prepared that if you want real multitasking combined with real time
programming on a system, which does not compare to "real PCs"
(again no punt intended!), you will have to solve several <hrrmmmm>
challenges....
Especially when audio/video recording/playback is
involved.
HTH!
Best regards,
mcc
ok thankyou mr.meino. I will try with what you have suggested and ll report back!!
