Cross Compilation Error ( almost done )
Hi all,
I almost configured my cross compilation configuration, but I got an error that I can’t understand …
First, I copy all the folder from my beaglebone to : /home/mickadev/BeagleBone/BeagleFile/
After that, it was easy to know where was my include folder and my lib folders.
The last problems that I solved, was that a couple of lib missed in the /usr/lib folder …
The reason is explained here : http://askubuntu.com/questions/40416/why-is-lib-libc-so-6-missing
I tried that :
sudo ln -s /lib/i386-linux-gnu/libc.so.6 /lib/libc.so.6
but the compiler said that it was not compatible, so I choosed to do that instead :
sudo ln -s /usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/lib/ld-linux.so.3 /lib/ld-linux.so.3
which works !
But now, I got :
/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/…/…/…/…/arm-angstrom-linux-gnueabi/bin/ld: warning: libXinerama.so.1, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link)
So, I tried to add the -rpath flag, but it didn’t work … and now, I don’t know what I can do … a big wall is in front of me . Can someone explain me where I’m wrong ? What can I do ? some tips ? ^^, thx you.
Micka,
make all
Building target: modIHM
Invoking: Cross G++ Linker
/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-g++ -v -Wall -L/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/lib -L/home/mickadev/BeagleBone/BeagleFile/usr/lib -rpath=/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/lib -o “modIHM” ./src/AButton.o ./src/AModIHM.o ./src/GtkCallBack.o ./src/ModIHM.o ./src/TemplateLayer.o ./src/TemplateMenu.o ./src/main.o -lgtk-3 -lgdk-3 -latk-1.0 -lgio-2.0 -lpangoft2-1.0 -lpangocairo-1.0 -lgdk_pixbuf-2.0 -lcairo-gobject -lcairo -lpango-1.0 -lfreetype -lfontconfig -lgobject-2.0 -lglib-2.0
Using built-in specs.
Target: arm-angstrom-linux-gnueabi
Configured with: /OE/angstrom/build/tmp-angstrom_2008_1/work/i686-armv7a-sdk-angstrom-linux-gnueabi/gcc-cross-sdk-4.3.3-r23.4/gcc-4.3.3/configure --build=i686-linux --host=i686-linux --target=arm-angstrom-linux-gnueabi --prefix=/usr/local/angstrom/arm --exec_prefix=/usr/local/angstrom/arm --bindir=/usr/local/angstrom/arm/bin --sbindir=/usr/local/angstrom/arm/bin --libexecdir=/usr/local/angstrom/arm/libexec --datadir=/usr/local/angstrom/arm/share --sysconfdir=/usr/local/angstrom/arm/etc --sharedstatedir=/usr/local/angstrom/arm/share/com --localstatedir=/usr/local/angstrom/arm/var --libdir=/usr/local/angstrom/arm/lib --includedir=/usr/local/angstrom/arm/include --oldincludedir=/usr/local/angstrom/arm/include --infodir=/usr/local/angstrom/arm/share/info --mandir=/usr/local/angstrom/arm/share/man --enable-largefile --disable-nls --enable-ipv6 --with-gnu-ld --enable-shared --enable-languages=c,c++,objc,fortran --enable-threads=posix --disable-multilib --enable-c99 --enable-long-long --enable-symvers=gnu --enable-libstdcxx-pch --program-prefix=arm-angstrom-linux-gnueabi- --enable-target-optspace --enable-cheaders=c_std --enable-libssp --disable-bootstrap --disable-libgomp --disable-libmudflap --with-sysroot=/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi --with-build-time-tools=/OE/angstrom/build/tmp-angstrom_2008_1/sysroots/i686-linux/usr/armv7a/arm-angstrom-linux-gnueabi/bin --with-build-sysroot=/OE/angstrom/build/tmp-angstrom_2008_1/sysroots/armv7a-angstrom-linux-gnueabi --disable-libunwind-exceptions --disable-libssp --disable-libgomp --disable-libmudflap --with-mpfr=/OE/angstrom/build/tmp-angstrom_2008_1/sysroots/i686-linux/usr --enable-__cxa_atexit
Thread model: posix
gcc version 4.3.3 (GCC)
COMPILER_PATH=/usr/local/angstrom/arm/libexec/gcc/arm-angstrom-linux-gnueabi/4.3.3/:/usr/local/angstrom/arm/libexec/gcc/arm-angstrom-linux-gnueabi/4.3.3/:/usr/local/angstrom/arm/libexec/gcc/arm-angstrom-linux-gnueabi/:/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/:/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/:/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/…/…/…/…/arm-angstrom-linux-gnueabi/bin/
LIBRARY_PATH=/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/:/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/…/…/…/…/arm-angstrom-linux-gnueabi/lib/:/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/lib/:/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/usr/lib/
COLLECT_GCC_OPTIONS=’-v’ ‘-Wall’ ‘-L/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/lib’ ‘-L/home/mickadev/BeagleBone/BeagleFile/usr/lib’ ‘-frpath=/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/lib’ ‘-o’ ‘modIHM’ ‘-shared-libgcc’
/usr/local/angstrom/arm/libexec/gcc/arm-angstrom-linux-gnueabi/4.3.3/collect2 --sysroot=/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi --eh-frame-hdr -dynamic-linker /lib/ld-linux.so.3 -X -m armelf_linux_eabi -o modIHM /usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/usr/lib/crt1.o /usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/usr/lib/crti.o /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/crtbegin.o -L/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/lib -L/home/mickadev/BeagleBone/BeagleFile/usr/lib -L/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3 -L/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/…/…/…/…/arm-angstrom-linux-gnueabi/lib -L/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/lib -L/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/usr/lib ./src/AButton.o ./src/AModIHM.o ./src/GtkCallBack.o ./src/ModIHM.o ./src/TemplateLayer.o ./src/TemplateMenu.o ./src/main.o -lgtk-3 -lgdk-3 -latk-1.0 -lgio-2.0 -lpangoft2-1.0 -lpangocairo-1.0 -lgdk_pixbuf-2.0 -lcairo-gobject -lcairo -lpango-1.0 -lfreetype -lfontconfig -lgobject-2.0 -lglib-2.0 -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/crtend.o /usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/usr/lib/crtn.o
/usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXi.so.6, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXrandr.so.2, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXext.so.6, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXcursor.so.1, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXcomposite.so.1, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXdamage.so.1, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXfixes.so.3, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libpixman-1.so.0, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libxcb-shm.so.0, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libxcb-render.so.0, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXrender.so.1, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libX11.so.6, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libxcb.so.1, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXau.so.6, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libXdmcp.so.6, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libpng12.so.0, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libz.so.1, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libgmodule-2.0.so.0, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libexpat.so.1, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libgthread-2.0.so.0, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: warning: libffi.so.6, needed by /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so, not found (try using -rpath or -rpath-link) /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libatk-1.0.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgio-2.0.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libpangoft2-1.0.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libpangocairo-1.0.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk_pixbuf-2.0.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo-gobject.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libpango-1.0.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libfreetype.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libfontconfig.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgobject-2.0.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libglib-2.0.so: Unknown EABI object attribute 34 /usr/local/angstrom/arm/lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: Warning: /home/mickadev/BeagleBone/BeagleFile/usr/lib/libm.so: Unknown EABI object attribute 34 /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgio-2.0.so: undefined reference to `deflateInit_' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XReparentWindow' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so: undefined reference to `g_module_open' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XConvertSelection' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_render_pictdepth_next' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XIFreeDeviceInfo' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `png_read_info@PNG12_0' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XIUndefineCursor' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XQueryColors' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XShapeCombineRectangles' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgio-2.0.so: undefined reference to `deflateInit2_' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XRenderSetPictureFilter' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XGetImage' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libfontconfig.so: undefined reference to `XML_ErrorString' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XmbSetWMProperties' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XGetMotionEvents' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XcursorShapeLoadImages' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libfontconfig.so: undefined reference to `XML_SetUserData' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XRenderFreeGlyphs' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSyncQueryExtension' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XRenderChangePicture' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XShapeQueryExtension' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_get_maximum_request_length' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XRRGetOutputInfo' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XAllocSizeHints' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSetWindowBackgroundPixmap' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XCompositeGetOverlayWindow' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `pixman_image_get_stride' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_poly_fill_rectangle' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XRenderCompositeText32' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XFreeColormap' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XRestackWindows' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_wait_for_reply' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `png_set_filler@PNG12_0' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XcursorImageLoadCursor' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_render_add_glyphs' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XScreenNumberOfScreen' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XRRGetScreenResourcesCurrent' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XFreeDeviceList' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_render_query_pict_formats_screens_iterator' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XCreatePixmap' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XIUngrabDevice' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `png_set_packing@PNG12_0' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XRRQueryVersion' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so: undefined reference to `XSendEvent' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XGetDefault' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSyncValueIsZero' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgtk-3.so: undefined reference to `XGetWindowProperty' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_create_pixmap_checked' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XUngrabDevice' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_render_change_picture' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XCreateSimpleWindow' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSetErrorHandler' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_render_query_pict_formats_reply' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `pixman_rasterize_trapezoid' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XQueryExtension' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSyncIntsToValue' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSynchronize' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XESetCloseDisplay' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_screen_allowed_depths_iterator' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XFreeEventData' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XGrabPointer' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XcursorSetDefaultSize' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XRenderCreateSolidFill' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `pixman_image_composite32' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `pixman_region32_contains_point' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `pixman_image_get_data' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XRRFreeOutputInfo' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XProcessInternalConnection' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XRenderFindVisualFormat' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XIQueryPointer' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_get_setup' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_render_create_linear_gradient' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XRRFreeScreenResources' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XQueryTree' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XPeekEvent' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XIWarpPointer' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSetWMHints' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XkbLibraryVersion' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XkbKeysymToModifiers' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgio-2.0.so: undefined reference to `deflate' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSetCloseDownMode' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_flush' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XCopyArea' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `xcb_shm_id' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `XRenderFindStandardFormat' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `pixman_region32_rectangles' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgdk-3.so: undefined reference to `XSetWMNormalHints' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libgobject-2.0.so: undefined reference to `ffi_type_double' /home/mickadev/BeagleBone/BeagleFile/usr/lib/libcairo.so: undefined reference to `pixman_image_get_width'
