I’ve setup cross compile environment using Eclipse according to the guide here.
The cross compiler I use is Sourcery G++ Lite (2011-3-41). The setup is fine, I can remotely debug a simple program on my BeagleBoard.
The problem is where I want to develope a program to control my Point Grey camera and reference some libraries.
In Eclipse, I’ve set the compiler to include the header files, and set the linker to point to camera’s libs files (provided by Point Grey Inc), also with the arm-none-linux-gnueabi include and lib files.
And I got this error when trying to compile the project
~/CodeSourcery/Sourcery_G++_Lite/arm-none-linux-gnueabi/lib/libflycapture.so: undefined reference to
std::__detail::_List_node_base::_M_hook(std::__detail::_List_node_base*)@GLIBCXX_3.4.15’
~/CodeSourcery/Sourcery_G++_Lite/arm-none-linux-gnueabi/lib/libflycapture.so: undefined reference to `std::__detail::_List_node_base::_M_transfer(std::__detail::_List_node_base*, std::__detail::_List_node_base*)@GLIBCXX_3.4.15’
I had checked the libstdc++.so in cross compiler dir, and it shows that GLIBCXX_3.4.15 is there
strings libc/usr/lib/libstdc++.so | grep GLIBC
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBC_2.4
GLIBCXX_FORCE_NEW
GLIBCXX_DEBUG_MESSAGE_LENGTH
My guess is Eclipse uses other libstdc++ file other than the one provided by arm-none-linux-gnueabi.
And I greatly appreciate your helps.
