Hi all,
I have one audio source code from http://www.suse.de/~mana/alsa090_howto.html,
and I want to cross compile it and test it on beagleboard.
when I use the following command,
arm-none-linux-gnueabi-gcc -o playback -lasound playback.c
it did not find the alsa/alsound.h file, however when I try gcc -o
playback -lasound playback.c, it works fine. I think the main problem
should be include path is not set correct for cross compile.
how to set the include path for this?
there is not a alsa/alsound.h in your cross compile,you need add it to
your cross compile
