Hello Folks,
I’m having a lot problems cross compiling from my Host PC which is an AMD x86 computer (HOST) with Ubuntu 14.04 TLS installed on it. I am trying to cross compile to my BeagleBone Black (TARGET) which has Debian-Jessie installed on it.
During cross compiling with Qt5.3 to my BBB, I was getting errors regarding the libQt5 files being the wrong format.The error message I receive is “cannot execute binary file, exec format error”.
Does anyone know how to cross compile correctly with Qt5.X from a host x86 computer which has Ubuntu 14.04 installed to a BeagleBone Black- Debian Jessie?
I would really appreciate your help in this urgent matter.
Hello Folks,
I'm having a lot problems cross compiling from my Host PC which is an AMD
installed on it.
"cannot execute binary file, exec format error".
"gnueabihf" compiler....
Jessie?
In general the cross compiler won’t know about system packages such as Qt so you can get horrible
incompatibility problems if you accidentally use those of the host as opposed to the target. Complete
build system such as bitbake deal with all this sort of stuff, but if you want something simpler you can
use “debootstrap” which can download the appropriate headers etc for the target system.
Hello Wulf Man
Thanks for the link. I already went through it step by step and still having issues cross comping from x86 to the ARM BBB. is there a way to check what perhaps libraries or modules I am missing?
This is really getting frustrating and I have checked and rechecked all the pertinent files.
I am currently working with Tim on this project, I am currently running into an issue installing crossbuild-essential-armhf, with the following error:
The following packages have unmet dependencies:
crossbuild-essential-armhf : Depends: libc6-dev:armhf but it is not installable
Depends: gcc-arm-linuxgnueabihf (>= 4.9.1-1) but it is not going to be installed
Depends: g+±arm-linuxgnueabihf (>= 4.9.1-1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
