Cross Compiling uboot - devkit 8000
HI,
i am using Devkit 8000 board, i recently cross compiled my u-boot source *'u-boot-1.3.3*' available in the TIMLL's provided CD.
i cross compiled using these steps,
*make CROSS_COMPILE=arm-none-linux-gnueabi- distclean
make CROSS_COMPILE=arm-none-linux-gnueabi- omap3devkit8000_config
**make CROSS_COMPILE=**arm-none-linux-gnueabi-** all*
and obtained the following error
*hello_world.c:1: error: bad value (armv7a) for -march= switch
make[1]: *** [hello_world.o] Error 1
make[1]: Leaving directory `/home/dcsystem2/Desktop/tmp_usage/u-boot-1.3.3/examples'
make: *** [examples] Error 2
*what could be done to get the uboot compiled.
Prabu.J
Because the TimLL’s U-Boot 1.3.3 is very old,
I guess you need a old version of ARM cross compiler.
In my experience,
1.3.3 is fail to be compiled with arm2009q3, arm2010q1
(I means CodeSourcery G++ Lite),
but can be compiled with arm2007q3 only.
2010/5/26 prabu <prabu.jkmr@gmail.com>
hi,
Thank you for your reply, where can i get the latest uboot supporting Devkit8000.
Prabu.J
林俊良 wrote:
I used latest Das U-Boot for DevKit8000
Website:
http://www.denx.de/wiki/U-Boot
Download release version source tarball:
ftp://ftp.denx.de/pub/u-boot/
And you also need newer version of linux-omap kernel
or you will not get to boot.
website: http://gitorious.org/devkit8000
get source by git plz…
$git git://gitorious.org/devkit8000/linux-omap-devkit8000.git
I used CodeSourcery G++ Lite arm2010q1.
And some commands for build:
Make u-boot.bin
cd u-boot-2010.03/
ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi-
make CROSS_COMPILE=arm-none-linux-gnueabi- mrproper
make CROSS_COMPILE=arm-none-linux-gnueabi- devkit8000_config
result: ./u-boot.bin
Make uImage
cd linux-omap-devkit8000/
make distclean
make ARCH=arm devkit8000_defconfig
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- uImage
result: ./arch/arm/boot/uImage
2010/5/26 林俊良 <goldie.lin@gmail.com>
Website:
sorry for a typo
$ git clone git://gitorious.org/devkit8000/linux-omap-devkit8000.git
hi,
I am trying to update the devkit8000 kernel, from the git repo.
After pulling the latest updates , I tried to build the kernel but it does not boot.
I use the openembedded generated toolchain, so CROSS_COMPILE is arm-angstrom-linux-gnueabi-
I build the uImage using
mkimage mkimage -A arm -O linux -T kernel -C none -a 0x80008000 -e 0x80008000 -n “Linux” -d vmlinux uImage
And the u-boot the is shipped with the board, U-Boot 1.3.3-svn (Feb 4 2010 - 15:16:04)
same for the x-loader.
The system is configured to load u-boot and kernel from nand and the filesystem from mmc
Booting kernel from Legacy Image at 80300000 …
Image Name: Linux
Data Size: 6675907 Bytes = 6.4 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
it stops here…
Fabio
The problem is the old U-Boot and newer U-Boot send different mach-id to kernel.
Try to replace the shipped U-Boot 1.3.3 with newer Das U-Boot (latest 2010.06).
The Das U-Boot latest stable version source can be found at: ftp://ftp.denx.de/pub/u-boot/
The building commands ref.: http://elinux.org/BeagleBoard#U-Boot
e.g.:
make CROSS_COMPILE=arm-none-eabi- mrproper
make CROSS_COMPILE=arm-none-eabi- devkit8000_config
(compile with “Sourcery G++ Lite for ARM EABI”)
Btw, I didn’t use the mkimage tool for converting vmlinux to uImage, but just directly use “make uImage”.
2010/7/31 fabio ferrario <ferrario.f@gmail.com>
I’ll try it out this afternoon. I’ll still stick to arm-angstrom-linux-gnueabi…
Using the Makefile out of the git repo “make uImage” was not available that’s why I used mkimage
Fabio
Well,
this fixed the boot problem but I have now new issues with the u-boot environment.
I used u-boot from the git repo so
U-Boot 2010.06-00236-g7385c28 (Aug 03 2010 - 12:01:32)
can you post the environment for the 7" lcd?
Fabio
check: http://gitorious.org/devkit8000/pages/Home
or mine:
$ vi boot.cmd
these bootargs look familiar to me, the lastest u-boot has a more elaborated scripting in the environment that allows ( I think so … ) for multiple boot options at runtime
Using the boot.scr out of the MMC should work an I’ll go for it, although I have u-boot and the kernel in NAND and the filesystem on the MMC
Fabio
Dear All,
I am also working on the devkit 8000 board.
please provide linux kernel information, I am using 2.6.34 kernel.i compiled with arm-linux-2009.
I got same result it’s not booted. I checked bdinfo(mach-id) in boot loader is differs from kernel.
so i loaded the u-boot.4.3 reload and boot the kernel.
saminath.
