Good evening.
I am following the instructions in the “EMbedded Linux Training” from Free Electrons (http://free-electrons.com) to setup my environment to build Beaglboard code. However, I am having difficulty getting the ct-ng toolchain to build properly. Whenever I issue the build command, I receive the following:
wws@wws-HP-Compaq-nc8430-EY685AW-ABA:~/crosstool-ng-1.12.4$ ./ct-ng build
[INFO ] Performing some trivial sanity checks
[INFO ] Build started 20120512.220555
[INFO ] Building environment variables
[EXTRA] Preparing working directories
[ERROR]
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions]
[ERROR] >> called from: CT_DoForceRmdir[scripts/functions@356]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@229]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: ‘build.log’
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> ‘docs/B - Known issues.txt’
[ERROR]
[ERROR] Build failed in step ‘Dumping user-supplied crosstool-NG configuration’
[ERROR]
[ERROR] (elapsed: 0:00.55)
[00:01] / make: *** [build] Error 1
ANy suggestions as to where to start?
Walt
