with the following files
1. MLO as MLO
2. u-boot as u-boot.bin
3. u-boot for flash as u-boot-f.bin
4. ramdisk image as ramdisk.gz
5. Kernel (uImage) as uImage.bin
6. reset.scr as boot.scr
7. x-loader image as x-load.bin.ift
8. Regular script file as normal.scr
its able to boot now but my monitor is not able to display with
warning "unable to display please set input computer to
1280x1024@60Hz"
Hi Koen what is your sequence to copy these files?
The only one that really matters is to copy the MLO file first. In
some cases, long file names can confuse u-boot, so try to avoid
copying files with long file names early in the process.
When is the Beagle XM going to be available for purchase?
Digitkey have leadtime = 17 Nov 2010 and google does not give any other
information.
Not a good idea to thread hijack for such a question. I'm currently
thinking we'll start shipping to Digi-Key when the new memories arrive
at the end of this month.
OMAP3530-GP ES3.1, CPU-OPP2 L3-165MHz
I2C: ready
DRAM: 256 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Board revision C4
Die ID #3554000400000000040373050f01a006
OMAP3 beagleboard.org # boot
mmc1 is available
reading boot.scr
** Unable to read "boot.scr" from mmc 0:1 **
reading uImage
3194800 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3194736 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
But then everything runs fine.
I havent flashed to nand yet, so I am thinking this could solve the **
Unable to read "boot.scr" from mmc 0:1 ** issue, but I was just
curious.
Is boot.src something that isnt needed with newer versions, and that
is why Angstrom will still boot properly?
