I’m running Angstrom on a Beagleboard-xM rev c4. My external LCD display is connected to S-Video and works fine but the image quality is fuzzy and quite awful. The screen is also cut off at the top and bottom.
I believe this is because the LCD is natively 800x480 but the beagleboard forces me to use NTSC or PAL. Is there a way to get 800x480 from the TV out instead? I tried omapfb.mode=800x480MR-24@60 (instead of omapfb.mode=tv:ntsc) and it refused to work at all. Thanks.
Ah I see. Well that's not really an option for what I'm doing... Is
there any way to fix the overscan at least, or make the interface
compensate for it somehow?
you cannot turn off overscan on your TV, the only thing you can do is
not to use the full area for displaying your UI or whatever...
