I just followed instructions at this site:
http://bec-systems.com/site/501/best-practices-for-building-qt-applications-with-openembedded/comment-page-1#comment-447
After dealing some issues, I succeeded to compile a qt4 application
and required qt4-embedded libraries in OE for Angstrom on BeagleBoard.
I tried to install the qt4 app on BeagleBoard, got the report of
missing qt libraries as expected, which are libqtguie4, libqtnetworke4
and libqtcoree4. The required version is (>=4.4.3) for each. I just
wanted to give a try to native opkg packages and installed those 3
libraries from opkg repository. Note that their version is 4.4.1. Then
I tried to install my qt4 app, not surprisingly, I got the same error
due to the version problem. Next, I transferred the 4.4.3 versions of
these 3 libraries from OE to BeagleBoard and tried to install them
without removing the already installed ones. I got errors. Then I
removed the old packages and do a clean install for new packages.
Here's what I got as the error report:
root@beagleboard:/home/admin# opkg install ./libqtcoree4_4.4.3-
r10.1_armv7a.ipk
./libqtnetworke4_4.4.3-r10.1_armv7a.ipk ./libqtguie4_4.4.3-
r10.1_armv7a.ipk
Multiple packages (libqtguie4 and libqtguie4) providing same name
marked HOLD or PREFER. Using latest.
Installing libqtguie4 (4.4.3-r10.1) to root...
Multiple packages (libqtnetworke4 and libqtnetworke4) providing same
name marked HOLD or PREFER. Using latest.
Installing libqtnetworke4 (4.4.3-r10.1) to root...
Configuring libqtnetworke4
Configuring libqtguie4
Collected errors:
* ERROR: Cannot satisfy the following dependencies for libqtguie4:
* libqtcoree4 (>= 4.4.3) * libqtcoree4 (>= 4.4.3) *
Note that I tried to install the 3 packages at the same time.
And this is what I got when I tried liqtcore separately:
r10.1_armv7a.ipk
Collected errors:
* libqtnetworke4 (>= 4.4.3) * libqtcoree4 (>= 4.4.3) *
Then I noticed that, libqtguie and libqtnetworke seem installed. I
removed them and tried to install libqtcore separately again. Here's
what I got
r10.1_armv7a.ipk
Collected errors:
Apparently there is a cyclic dependency. Any idea?
Best regards,
Caner
