Hi all,
I have several BBB in my system (all rev C). I need them to be configured the same way so I thought about setting up one and copying the setup using dd between boards. In order to do this I used a uSD with 2 partitions, the first one containing a full system and the 2nd one aimed at storing the image from the eMMC.
I create the custom image from eMMC of the source board to the uSD card via:
root@beaglebone:~# dd if=/dev/mmcblk1 of=/dev/mmcblk0p3 bs=16M
234+0 records in
234+0 records out
3925868544 bytes (3.9 GB) copied, 306.985 s, 12.8 MB/s
and copy it from the uSD board to the eMMC of the destination board via:
root@beaglebone:~# dd if=/dev/mmcblk0p3 of=/dev/mmcblk1 bs=16M count=234
234+0 records in
234+0 records out
3925868544 bytes (3.9 GB) copied, 583.641 s, 6.7 MB/s
The operations run correctly but when I restart the destination board, I can never reach (whether its is via SSH to 192.168.7.2 or to the IP set for eth0, it does not work). I have also tried doing the dd to a file rather than to a partition, and changed the bs, but none of these options work. The only configuration that works is when the source and destination boards are the same (which is useless).
I initially thought I had bricked all my boards except the source, but then I tried to install an official flasher image (from Robert C. Nelson) on the destination boards, and it worked fine (at least with BBB-eMMC-flasher-debian-8.4-console-armhf-2016-04-10-2gb.img.xz and BBB-eMMC-flasher-debian-7.5-2014-05-14-2gb.img.xz). So my boards are actually not bricked.
I then tried to dd an official non-flasher image (also coming from Robert C Nelson), by putting the non-flasher image on the 2nd partition of my uSD card, mounting this partition and doing dd if=bone-debian-8.4-console-armhf-2016-04-10-2gb.img of=/dev/mmcblk1p1 but I had no luck.
So it seems I can install the official flasher images (using the auto-flashing system), but when I flash using dd it does not work (whether I flash custom or official images). This gives me the feeling that the different boards are slightly different in hardware, could this be possible? Could this come from dead sectors in the eMMC? Is there a way to use the auto-flashing system with a custom image?
I have looked for days on the internet how to go forward and get my dds right but cannot find any answer.
Any idea of what I am doing wrong?
Antoine.
