dd emmc to SD will not boot (flasher image)
The uboot boot selection only has an option for emmc, so when trying to test the dd of emmc to SD it will hang. It needs a 5th option for SD card boot to point to SD card.
You can edit this manually in extlinux.conf in /boot to create your own boot menu entries without recompiling. Is this on BBB or some other board?
Its the bp, uboot has a script to run during boot.
