While installing Ubuntu on to the beagleboard-xm by Netinstall method I getting the deb error as follows:
delete the file and rerun, as i've been monkeying around with the
(rcn-ee.net) server to try and get a few things to "upgrade"..
For reference:
voodoo@hestia:/opt/github/netinstall$ md5sum
dl/oneiric-armel/linux-image-3.7.10-x10_1.0oneiric_armel.deb
47e2a5e73c774c6740b57daa0207b9f5
I have deleted the file(linux-image-3.7.10-x10_1.0oneiric_armel.deb) and ran the commands once again. But the issue is not solved. I am facing the same error.
Well as it still "works for me" can you please provide a little more info..
Run "md5sum" on the file:
md5sum dl/oneiric-armel/linux-image-3.7.10-x10_1.0oneiric_armel.deb
What do you get?
If it's : 47e2a5e73c774c6740b57daa0207b9f5
Next what distribution are you running on your pc and what version of dpkg?
dpkg --version
Then i can atleast try to replicate your issue..
I ran command “md5sum /home/tilab/netinstall/dl/oneiric-armel/linux-image-3.7.10-x10_1.0oneiric_armel.deb”
and output was “924e186877d0f8d6d302bc7f42317631 /home/tilab/netinstall/dl/oneiric-armel/linux-image-3.7.10-x10_1.0oneiric_armel.deb”
I am using Ubuntu 11.10 version. How to know the version of dpkg?
I ran command "md5sum
/home/tilab/netinstall/dl/oneiric-armel/linux-image-3.7.10-x10_1.0oneiric_armel.deb"
and output was "924e186877d0f8d6d302bc7f42317631
Something between you and your "internet" is broken... Fix it..
Server side:
[ps126131]$ md5sum linux-image-3.7.10-x10_1.0oneiric_armel.deb
47e2a5e73c774c6740b57daa0207b9f5 linux-image-3.7.10-x10_1.0oneiric_armel.deb
When i download it:
aka: your ouput "924e186877d0f8d6d302bc7f42317631" does not equal
"47e2a5e73c774c6740b57daa0207b9f5" so please "fix your network
connection"..
"dpkg --version"
as mentioned previously.
How to know the dpkg version in Ubuntu operating system?
type: dpkg --version
Otherwise it doesn't matter... Your network/system is corrupting the
'file' in transit..
