Debian 7.3 cannot boot....
Hi, everyone
The rootfile system of BBB (Debian 7.3) cannot boot as below.
Please tell me any hint about it.
Thanks in advance
INIT: version 2.88 booting
[info] Using makefile-style concurrent boot in runlevel S.
[…] Starting the hotplug events dispatcher: udevd[ 4.187969] udevd[195]: starting version 175
. ok
[…] Synthesizing the initial hotplug events…done.
[…] Waiting for /dev to be fully populated…done.
[…] Activating swap…done.
[ 6.679857] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[…] Cleaning up temporary files… /tmp. ok
[…] Activating lvm and md swap…done.
[…] Checking file systems…fsck from util-linux 2.20.1
done.
[…] Mounting local filesystems…done.
[…] Activating swapfile swap…done.
[…] Cleaning up temporary files… ok
[…] Setting kernel variables …done.
[…] Configuring network interfaces…done.
INIT: aEntering runlevel: 2
[info] Using makefile-style concurrent boot in runlevel 2.
[…] Starting enhanced syslogd: rsyslogdThu Dec 19 02:03:00 UTC 2013
. ok
[…] Starting web server: apache2apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.1.1 for ServerName
. ok
[…] Loading cpufreq kernel modules…done (none).
[…] Starting periodic command scheduler: cron. ok
[…] Starting system message bus: dbus. ok
[…] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon. ok
[…] CPUFreq Utilities: Setting ondemand CPUFreq governor…CPU0…done.
[…] Starting OpenBSD Secure Shell server: sshd. ok
udhcpd: Disabled. Edit /etc/default/udhcpd to enable it.
