(1) System bb1cf1 got installed with 3.19.3-bone4: no more reboot
uptime
03:23:37 up 14:50, 1 user, load average: 0.00, 0.01, 0.05
(2) System bb6c1f: installed with 4.1.1-ti-r2 #1 SMP PREEMPT Wed Jul 8 17:03:29 UTC 2015 armv7l GNU/Linux: 2 reboots
Jul 13 00:55:17 bb6c1f kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jul 13 01:51:02 bb6c1f kernel: [ 0.000000] Booting Linux on physical CPU 0x0
(3) System bb4f8e still has 4.1.0-rc8-bone9 #1 Wed Jun 17 00:05:43 UTC 2015 armv7l GNU/Linux: but cpufreq-set -g performance: no more reboot
uptime
03:29:57 up 9:01, 1 user, load average: 0.02, 0.06, 0.05
As I have to leave for the day, I will let all my systems run for at least 12h without changes.
If then still like this, I will do (1) and (3) on some more devices.
@RobertCNelson: If you have further suggestions which image to test, let me know.
I took my Rev.C unit (1c:ba:8c:d9:5e:dd) and loaded “bone-debian-8.1-lxqt-4gb-armhf-2015-07-05-4gb.img” onto a
16 GB uSD card. Unit, power supply and card are “trusted.”
Absolutely no changes to the image, just install, boot, run. No updates, additions or modifications.
No cape, only connections are 5V power and Ethernet.
Times are GMT/UTC. I define the boot completion as the time when systemd updates the internal time from the network.
What does "cpufreq-set -g performance" do?
Sounds like it would lock the BBB at max CPU clock speed, or at least, not
let it go down to the lowest speeds.
Correct...
I found the generic Debian docs on cpufreq-set, but not the BBB specific
instruction set and meanings.
It's a generic kernel interface, nothing bbb specific about it..
Ok, so what I am wondering is: Why if this is kernel does the kernel work fine for me. When using a Wheezy 7.8 rootfs ? It is fairly safe to say that in my own case this is not related to kernel, or kernel modules . . .right ?
(1) System bb1cf1 got installed with 3.19.3-bone4: still no reboot
uptime
04:19:11 up 1 day, 13:51, 2 users, load average: 0.00, 0.01, 0.05
(2) System bb6c1f: installed with 4.1.1-ti-r2 #1 SMP PREEMPT Wed Jul 8 17:03:29 UTC 2015 armv7l GNU/Linux: 2 reboots to a total of 4
Jul 13 21:46:08 rc6c1f kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jul 14 04:02:45 rc6c1f kernel: [ 0.000000] Booting Linux on physical CPU 0x0
(3) System bb4f8e still has 4.1.0-rc8-bone9 #1 Wed Jun 17 00:05:43 UTC 2015 armv7l GNU/Linux: but cpufreq-set -g performance: rebooted 15:50 after around 20h uptime, before it had 6 reboots within 24h
(4) some other systems ran with cpufreq-set -g performance, feeling is that the number of reboots decreased
My conclusion:
cpufreq-set -g performane seems to improve the situation, but does not solve it.
Could this possibly be related to how “clean” provided AC mains is ? I’m just curious, as we’ve never had any of these problems, but we’re also completely off grid. Also for the record our power here is very stable and clean. No blips, spikes, or any abnormalities one might see being connected to grid power.
Anyway my last comment was a bit of a stretch. Seeing as this only effects some boards, and not all. However it does strike me as odd that both of you are having issues with the same kernel I’m running right_now. When it is running rock solid so far for me.
Which leads me to believe that something on the rootfs is perhaps somehow to blame. Either that, on something on these failing boards is somehow slightly out of tolerance. I’ll let this run a while longer just to make sure before moving on to a Jessie image.
Do also keep in mind that while we do not own 100’s of BBB’s we do own 5, and none of these have ever shutdown without a reason . . . 2 A5A’s and 3 element14 REVC’s
I installed 4.1.2-ti-r3 on 13 devices. Without executing cpufreq-set -g performance.
First impression is not good, as I had 3 reboots since then, but more info after the night about 8h.
That shouldn't matter.. Mine rebooted after 3 hours.. I'm also
unplugging the ethernet to test an offline "npm install xyz" script..
what's odd, it rebooted on "git pull"..
