I installed the following image on a BBB version 5AC:#### microSD/Standalone: (stretch-iot) (All BeagleBone Variants & PocketBeagle)
bone-debian-9.3-iot-armhf-2018-02-18-4gb
Everyting is running fine (at least what I tested: node-red).
The BBB boot button was pushed at startup right at the beginning ( boot on the µSD card ).
The problem is that it has to be repeated (button pushed) after a power outage (in case of a clean shutdown (UPS) after power outage), Otherwise the BBB doesn’t simply boot up. That can be a problem in case of remote installation. I don’t see any warning in the wiki about this behavior
It may be a hardware problem on my rather old BBB ver 5AC. Does anybody encountered the same issue ?
On Fri, 23 Feb 2018 03:27:35 -0800 (PST),
mich.gerin@gmail.com declaimed the following:
*microSD/Standalone: (stretch-iot) (All BeagleBone Variants & PocketBeagle)
**bone-debian-9.3-iot-armhf-2018-02-18-4gb*
<SNIP>
the BBB doesn't simply boot up. That can be a problem in case of remote
installation. I don't see any warning in the wiki about this behavior
More likely, it is an antique image on the eMMC.
I believe it was only about a year or so ago that images were
configured so that the eMMC boot-loader would look at and boot an installed
SD card without needing the boot button.
Second, newer images are expecting u-Boot device tree (overlay)
handling, whereas the older images put-off device tree overlay handling
until Linux had booted.
You will probably need to obtain a 2GB image (I presume the "5AC" in
your subject meant "A5C" version), verify that boots from SD card (using
the button), convert to flasher image, flash the eMMC, remove SD card and
verify unit boots from eMMC.
THEN install your 4GB SD card image and see if the board now detects
and boots from it without holding down the button.
Probably an Old MLO / uboot.img on the eMMC. If the newer is flashed to the eMMC, this problem would probably go away. I’ve experienced this on many boards myself as / when I forget to update the eMMC.
