Debian demo image 2014-07-06 -> initrd.img, uEnv.txt, dtbs and zImage are missing
Hi everybody,
with the old demo images (2014-06-05 and older) I could make a “working” SD card.
With the newest update (2014-07-06) the files mentioned in the subject are missing on the card, when I create it with:
sudo ./setup_sdcard.sh --mmc /dev/sda --dtb beaglebone
with the files from here:
http://rcn-ee.net/deb/rootfs/wheezy/debian-7.5-console-armhf-2014-07-06.tar.xz
as described by Robert here: http://elinux.org/BeagleBoardDebian#Debian_Stable_.28wheezy.29
Can somebody give me a hint what I am missing?
Best regards,
Michael
Just plug it in and let it boot. (Unless you have an old bootloader in
the bbb's eMMC)
I had some free time over the holiday weekend, so I implemented two
big changes, repos.rcn-ee.net is now up (sudo apt-get install
linux-image-$(rcn-ee.net kernel), along with firmware and header
packages) and i rewrote my bootloader patch to take advantage of some
new u-boot features.
The spec is here: http://elinux.org/Beagleboard:U-boot_partitioning_layout_2.0
With debian jessie, this means you can install debian's kernel
packages and swap between the kernels via updating /boot/uEnv.txt's
uname_r variable.
However if your running the BBB, i just finished the uEnv.txt
compatibility shim yesterday. (which means it isn't in the 2014-07-06,
release)
For future reference purposes the option is:
--bbb-old-bootloader-in-emmc
as of: https://github.com/beagleboard/image-builder/commit/30e006546228418dc57611c967b86778916f5be4
To update the "setup_sdcard.sh" in 2014-07-06 to support that:
rm setup_sdcard.sh
wget https://raw.githubusercontent.com/beagleboard/image-builder/master/tools/setup_sdcard.sh
chmod +x setup_sdcard.sh
Dear Robert,
thank you very much for your quick response!
Your crystal ball was again correct: I had an old bootloader on the eMMC. I updated the eMMC to your latest image and now it is working.
With debian jessie, this means you can install debian’s kernel packages and swap between the kernels via updating /boot/uEnv.txt’s uname_r variable.
This sounds great!
Best regards,
Michael
