I’m a newbie with beaglebones black running debian…
The problem arises with a beaglebone black rev c and the image BBB-eMMC-flasher-debian-8.3-iot-armhf-2016-03-13-4gb.img, but also happened with BBB-eMMC-flasher-debian-8.3-lxqt-4gb-armhf-2016-03-13-4gb.img.
I cannot access the network through eth0.
The same beaglebone worked with a debian wheezy image installed…
Here is the problem:
I’ve found the instructions on the thread https://groups.google.com/forum/#!topic/beagleboard/7pex-V9vYWw and removed connman, but the problem remains.
I have the following configuration on the beaglebone:
**** /etc/network/interfaces file:
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet static
address 192.168.20.79
netmask 255.255.255.0
network 192.168.20.0
broadcast 192.168.20.255
gateway 192.168.20.1
dns-name-servers 192.168.20.200
iface usb0 inet static
address 192.168.7.2
netmask 255.255.255.252
network 192.168.7.0
gateway 192.168.7.1
**** /etc/resolv.conf:
nameserver 192.168.20.200
nameserver 8.8.8.8
nameserver 4.4.4.4
**** ifconfig command returns:
eth0 Link encap:Ethernet HWaddr 54:4a:16:f0:f1:f0
inet addr:192.168.20.79 Bcast:192.168.20.255 Mask:255.255.255.0
inet6 addr: fe80::564a:16ff:fef0:f1f0/64 Scope:Link
RX packets:2652 errors:0 dropped:1 overruns:0 frame:0
TX packets:2218 errors:16 dropped:63 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:272369 (265.9 KiB) TX bytes:15461 (15.0 KiB)
Interrupt:175
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:388 errors:0 dropped:0 overruns:0 frame:0
TX packets:388 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:36764 (35.9 KiB) TX bytes:36764 (35.9 KiB)
usb0 Link encap:Ethernet HWaddr 54:4a:16:f0:f1:f1
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::564a:16ff:fef0:f1f1/64 Scope:Link
RX packets:886 errors:0 dropped:5 overruns:0 frame:0
TX packets:36 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:129397 (126.3 KiB) TX bytes:9712 (9.4 KiB)
***** iptables -L command returns:
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
**** route -n command returns:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.20.1 0.0.0.0 UG 0 0 0 eth0
192.168.7.0 0.0.0.0 255.255.255.252 U 0 0 0 usb0
192.168.20.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
REMARK: The first route I added manually - when the beaglebone boots, it was not configured, just the last two.
I cannot ping the beaglebone from another computer.
I cannot ping another computer from the beaglebone.
What am I missing?
Thanks in advance…
Daniel.
