Hi Vlad,
Vladimir Vukicevic wrote:
Hey Dirk,
I was just trying to follow your guide at BeagleBoardDebian - eLinux.org
This guide isn't from me, it's from Robert, see
http://groups.google.com/group/beagleboard/browse_thread/thread/538c104ba7abf570#
on getting debian going on the beagle -- I've got an install done on a 4GB SDHC card that I was using earlier for the angstrom demo image. If I try booting with the same kernel as I used for the angstrom image (2.6.26-omap1), I get to:
Waiting 1sec before mounting root device...
mmc0: host does not support reading read-only switch. assuming write- enable.
mmc0: new high speed SDHC card at address b368
mmcblk0: mmc0:b368 SD 3930624KiB
mmcblk0: p1 p2
kjournald starting. Commit interval 5 seconds
EXT3 FS on mmcblk0p2, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem).
Freeing init memory: 172K
Kernel panic - not syncing: Attempted to kill init!I'm unsure why init is either not being run, or is crashing, or something..
If I try the kernel you suggested on that page, the 2.6.18 uImage_OTG, it can't find mmcblk0p2 -- perhaps SDHC support landed after 2.6.18? For reference, the tail end of the boot messages:
<6>VFP support v0.3: VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
<6>cpuidle: using governor menu
<3>Root-NFS: No NFS server available, giving up.
<3>VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "mmcblk0p2" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
(... listed mtdblock parts)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown- block(2,0)I'm happy to build a new kernel, and will probably try doing so shortly, but I'm more curious as to why the original angstrom image can't seem to boot here. (I had no problems booting using qemu from the SD card, fwiw, so the install there is good.)
Any help would be appreciated!
Unfortunately, I have no idea. Didn't try the Debian way myself.
Looping in the mailing list and Robert, maybe they can help.
Please don't send private mails, always ask on the mailing list (or at IRC), there are more people to help.
Regards
Dirk
