Yeah I noticed that. I was hoping to go the ioctl route because I’m working on a cape that gives the option of RS232 or RS485 on UART4, so the runtime switching would be great.
Hopefully I’m just doing something stupid, but I can’t get it to work through ioctl. I’ve tried in both C and Python on an Angstrom image with 3.8, this testing image, and an old Angstrom with 3.2 on the original BB. The tests I’m trying are here: https://gist.github.com/alexanderhiam/8548894
On all three bones the C ioctl() call raise errno 25. On the two with 3.8 the Python ioctl() call raises ‘IOError: [Errno 25] Inappropriate ioctl for device’ and on the bone with 3.2 it raises ‘IOError: [Errno 22] Invalid argument’.
I was under the impression that you had to enable the RS485 ioctl settings when building the kernel, but I can’t remember where I got that idea and I haven’t actually tried it yet
About the RS485 support on the BBB, you have to modify the driver omap serial and control the gpio that you want. But if you want a quick solution, i already made a patch for that
[15841.027741] INFO: task wpa_supplicant:515 blocked for more than 60 seconds.
[15841.035254] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[15841.043567] wpa_supplicant D c045aae7 0 515 1 0x00000000
[15841.050462] Kernel panic - not syncing: hung_task: blocked tasks
[15841.056860] [] (unwind_backtrace+0x1/0x8a) from [] (panic+0x51/0x148)
[15841.065512] [] (panic+0x51/0x148) from [] (watchdog+0x14f/0x194)
[15841.073718] [] (watchdog+0x14f/0x194) from [] (kthread+0x67/0x74)
[15841.082011] [] (kthread+0x67/0x74) from [] (ret_from_fork+0x11/0x34)
[15841.090550] drm_kms_helper: panic occurred, switching back to text console
After rebooting, ethernet comes up, but the wifi doesn’t. According to syslog, it does try to authenticate but times out. This is a rtl8192cu based USB Wifi adapter (EDIMax), which I never have seen work reliably, so this many not be a connman issue.
Ideally I was hoping to use the RTS signal though. From what I had read that seemed to be the standard for UART RS485 mode in the Linux kernel, but looking into the omap_serial driver it looks like it wasn’t implemented (on 3.8 at least).
