Upon loading
BBB-eMMC-flasher-debian-jessie-lxqt-armhf-2014-11-11-2gb.img
onto two different BeagleBone Blacks, RevC, two different microSD cards,
image is untouched, unmodified,
both present the same failures...
as monitored on TTYO0
[ 14.438279] libphy: PHY 4a101000.mdio:01 not found
[ 14.443321] net eth0: phy 4a101000.mdio:01 not found on slave 1
[FAILED] Failed to start dnsmasq - A lightweight DHCP and caching DNS
server.
See 'systemctl status dnsmasq.service' for details.
[DEPEND] Dependency failed for Host and Network Name Lookups.
Thanks for testing! I'm pretty sure this is because we also have
udchpd on the image, both dhcp damon's are fighting for the socket..
ap-hotspot brings in dnsmasq.. might just have to disable that, as we
need udhcpd for bb.org
The experience of wireless routers that serve up a web login page could be rather helpful. It might also give us a way to get wireless adapters connected.
I'm using your 2014/11/11 jessie image and after I did an apt-get update/upgrade I lost the ability to connect with ssh. removing udhcpd and adding the above configuration for dnsmasq restored my ability to connect via ssh on both interfaces.
This was a bug originally in ubuntu (trusty) looks like the bug (maybe
feature now it's a feature...) has progressed to debian. I'll add the
workaround by default..
