Hi:
I'm having difficulty getting my usb ethernet adapter working. I
want to turn this process of fixing it into an general exercise I can
teach my students.
Here's the background for my problem:
I have an older image that boots up fine and eth0 works fine (as does
the usb keyboard and mouse).
Here's what 'uname -a' says about it:
Linux beagleboard 2.6.27-omap1 #2 Sun Jan 11 11:23:31 CET 2009 armv7l
unknown unknown GNU/Linux
I have a newer image where eth0 doesn't work (but the keyboard and
mouse do). Same hardware as before. uname -a says:
Linux beagleboard 2.6.28-omap1 #1 Fri Mar 20 01:11:29 EDT 2009 armv7l
GNU/Linux
So the question is: how to I track down this problem? Here's what I
did:
1. Run ifconfig
a. Old Image
# ifconfig
eth0 Link encap:Ethernet HWaddr 00:60:6E:00:03:16
inet addr:137.112.41.132 Bcast:137.112.41.255 Mask:
255.255.255.0
inet6 addr: fe80::260:6eff:fe00:316/64 Scope:Link
RX packets:1182 errors:0 dropped:0 overruns:0 frame:0
TX packets:826 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:78470 (76.6 KiB) TX bytes:68979 (67.3 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:12 errors:0 dropped:0 overruns:0 frame:0
TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:600 (600.0 b) TX bytes:600 (600.0 b)
b New Image
# ifconfig
RX packets:43 errors:0 dropped:0 overruns:0 frame:0
TX packets:43 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3184 (3.1 KiB) TX bytes:3184 (3.1 KiB)
usb0 Link encap:Ethernet HWaddr 6A:AC:00:2A:D4:6D
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Hmmm.... So it looks like eth0 never got set up.
2. Check dmesg.
a. Old Image
eth0: register 'dm9601' at usb-musb_hdrc-1.4, Davicom DM9601 USB
Ethernet, 00:60:6e:00:03:16
usbcore: registered new interface driver dm9601
b. New Image
usb 2-1.4: new full speed USB device using musb_hdrc and address 5
usb 2-1.4: device v0a46 p9601 is not supported
usb 2-1.4: configuration #1 chosen from 1 choice
Hmmm.... I'm guessing the driver didn't get installed, but why?
3. Search Discussions
I found some a discussion that suggests the newer kernel may not work
(http://groups.google.com/group/beagleboard/browse_thread/thread/
b4e1af42a8ad353f/850e76675db42165?lnk=gst&q=eth0#850e76675db42165),
but I don't know where to go from here.
4. Post a question.
And here we are. Where do I go from here?
BIG Question 1: Is this a reasonable way to approach a problem? Are
there other steps I should add? Is there more (or less) information
that should be put in the original post?
BIG Question 2: How do I get eth0 working on the new image?
Thanks...
--Mark
