I’m currently trying to set up cross-compiling for the Beaglebone Black. I am running Eclipse on my windows machine and Linaro-arm cross compiler. I can compile on Windows and run the program just fine on the BBB. My problem is trying to get the remote GDB to work. I’m run gdbserver on the BBB: gdbserver 192.168.7.2:12345 TestLED.elf
Process TestLED.elf created; pid = 2415 Listening on port 12345 Remote debugging from host 192.168.7.1
I’ve set up remote debugging in Eclipse using the GDB in the Linaro toolchain. I get the following in the console when I start up GDB in Eclipse:
$1 = 0xff Cannot access memory at address 0x0 Cannot access memory at address 0x0 The target endianness is set automatically (currently little endian) No source file named C:\Path\To\source\file\src\main.cpp.
I’ve built it using the debug option. So I’m assuming it compiled it with the -g flag.
I added the flag just in case and get the same error
EDIT: It appears I can step through it just fine in GDB on the bbb. So the problem seems to something in Eclipse.
