How can I set default booting option as boot from SD card on Beagle
Board xM?
I am making a demo system with Beagle Board xM.
I want to make Beagle Board xM boot from SD card without selecting
boot option from hyper terminal.
Please, let me know how I can do it.
Now I want to disable KITL and enable DHCP for network option.
Those my options are not saving, i.e. everytime when I boot up I need
to disable KITL and enable DHCP.
How I can save those network settings to flash to avoid serial
connection for every boot up?
Yes I know. But it is being phased out and will not be supported after the next batch of boards are shipped. If you have a -01 board, then yes there is NAND there but it is ignored by all the drivers created for the -xM.
So, exactly how can you brick an -xM? It can’t even boot from NAND unless of course you modify the board in some way by removing and soldering in resistors and then it wouldn’t be a -xM board any more.
The point i am trying to make is that there are ways to abuse the board and make it to where it will not boot. The idea is that you should not be able to brick the board in normal use. The only reason the NAND was there is because that is the only part we get get to get the boards shipping. It was not supplied by our choice. That is the reason we said not to use the NAND and that it would be removed. Your decision to use the NAND while definitley within your right to do so, you have to admit that it was within the normal usage of the board. Which again is your right. I can brick a board without even turning it on to let the SW do it. So, there is no HW out there that is brick proof if you really set out to do it.
Just to clarify, I was just answering to the question “So, exactly how can you brick an -xM? … wihtou modify the board in some way by removing and soldering in resistors”
and there is it how to brick it without hardware mods, nothing more nothing less. Nothing to do with ethics or morality or customer rigths or anything else, just a a straight answer
I have not started the topic, nor have complained about anything, or have asked how to recover a bricked xM that have been “abused” (this term is kind of a paradigm on a board marketed as a hackers and experimentation platform)
Just to clarify, I was just answering to the question "So, exactly how can you brick an -xM? .... wihtou modify the board in some way by removing and soldering in resistors"
And you still haven't shown how to brick it, since de-bricking would involve jtag. All you showed is a situation you can get out of with serload, which is not the same as 'bricked'. Over the years I've been doing this I've only bricked a board once (power brownout during uboot reflash). When we say the beagle is virtually unbrickable, that's because pretty much all the boot options (serload, pusb, sysboot pins) are available to the user.
So again, you did NOT brick it!
