Yes, I’m use a Beaglebone Black.
I have my own modifications to an official image. It’s very similar to image-builder/configs/bb.org-debian-bookworm-minimal-v6.1-ti-armhf-am335x.conf at master · beagleboard/image-builder · GitHub with other dependencies installed as well as a realtime 6.6 kernel (6.6.77-bone-rt-r23).
These are the outputs from udevadm test $(udevadm info --query=path --name=i2c-0) on different images:
I got this from this minimal bookworm image (linked here):
This program is for debugging only, it does not run any program
specified by a RUN key. It may show incorrect results, because
some values may be different, or not available at a simulation run.
Trying to open "/etc/systemd/hwdb/hwdb.bin"...
Trying to open "/etc/udev/hwdb.bin"...
Trying to open "/usr/lib/systemd/hwdb/hwdb.bin"...
Trying to open "/lib/systemd/hwdb/hwdb.bin"...
Trying to open "/lib/udev/hwdb.bin"...
=== trie on-disk ===
tool version: 252
file size: 12064506 bytes
header size 80 bytes
strings 2534898 bytes
nodes 9529528 bytes
Loading kernel module index.
Failed to read $container of PID 1, ignoring: Permission denied
Found cgroup2 on /sys/fs/cgroup/, full unified hierarchy
Found container virtualization none.
Using default interface naming scheme 'v252'.
Parsed configuration file "/usr/lib/systemd/network/99-default.link"
Parsed configuration file "/usr/lib/systemd/network/80-iwd.link"
Parsed configuration file "/usr/lib/systemd/network/73-usb-net-by-mac.link"
Created link configuration context.
Reading rules file: /etc/udev/rules.d/10-of-symlink.rules
Reading rules file: /usr/lib/udev/rules.d/40-usb_modeswitch.rules
Reading rules file: /usr/lib/udev/rules.d/50-firmware.rules
Reading rules file: /usr/lib/udev/rules.d/50-udev-default.rules
Reading rules file: /usr/lib/udev/rules.d/55-dm.rules
Reading rules file: /usr/lib/udev/rules.d/60-autosuspend.rules
Reading rules file: /usr/lib/udev/rules.d/60-block.rules
Reading rules file: /usr/lib/udev/rules.d/60-cdrom_id.rules
Reading rules file: /usr/lib/udev/rules.d/60-drm.rules
Reading rules file: /usr/lib/udev/rules.d/60-evdev.rules
Reading rules file: /usr/lib/udev/rules.d/60-fido-id.rules
Reading rules file: /usr/lib/udev/rules.d/60-i2c-tools.rules
Reading rules file: /usr/lib/udev/rules.d/60-infiniband.rules
Reading rules file: /usr/lib/udev/rules.d/60-input-id.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-alsa.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-input.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-dm.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-tape.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage.rules
Reading rules file: /usr/lib/udev/rules.d/60-persistent-v4l.rules
Reading rules file: /usr/lib/udev/rules.d/60-sensor.rules
Reading rules file: /usr/lib/udev/rules.d/60-serial.rules
Reading rules file: /etc/udev/rules.d/61-smsc95xx-mac-address.rules
Reading rules file: /usr/lib/udev/rules.d/64-btrfs-dm.rules
Reading rules file: /usr/lib/udev/rules.d/64-btrfs-zoned.rules
Reading rules file: /usr/lib/udev/rules.d/64-btrfs.rules
Reading rules file: /usr/lib/udev/rules.d/70-camera.rules
Reading rules file: /usr/lib/udev/rules.d/70-joystick.rules
Reading rules file: /usr/lib/udev/rules.d/70-memory.rules
Reading rules file: /usr/lib/udev/rules.d/70-mouse.rules
Reading rules file: /usr/lib/udev/rules.d/70-power-switch.rules
Reading rules file: /usr/lib/udev/rules.d/70-touchpad.rules
Reading rules file: /usr/lib/udev/rules.d/70-uaccess.rules
Reading rules file: /usr/lib/udev/rules.d/71-seat.rules
Reading rules file: /usr/lib/udev/rules.d/73-seat-late.rules
Reading rules file: /usr/lib/udev/rules.d/73-special-net-names.rules
Reading rules file: /usr/lib/udev/rules.d/75-net-description.rules
Reading rules file: /usr/lib/udev/rules.d/75-probe_mtd.rules
Reading rules file: /usr/lib/udev/rules.d/78-sound-card.rules
Reading rules file: /usr/lib/udev/rules.d/80-debian-compat.rules
Reading rules file: /usr/lib/udev/rules.d/80-drivers.rules
Reading rules file: /etc/udev/rules.d/80-gpio-noroot.rules
Reading rules file: /etc/udev/rules.d/80-i2c-noroot.rules
Reading rules file: /usr/lib/udev/rules.d/80-ifupdown.rules
Reading rules file: /usr/lib/udev/rules.d/80-net-setup-link.rules
Reading rules file: /etc/udev/rules.d/81-add-SoftAp0-interface.rules
Reading rules file: /usr/lib/udev/rules.d/81-net-dhcp.rules
Reading rules file: /etc/udev/rules.d/81-pwm-noroot.rules
Reading rules file: /etc/udev/rules.d/82-SoftAp0-start-hostpad.rules
Reading rules file: /etc/udev/rules.d/82-gpio-config-pin.rules
Reading rules file: /etc/udev/rules.d/83-counter-noroot.rules
Reading rules file: /etc/udev/rules.d/85-gpio-noroot.rules
Reading rules file: /usr/lib/udev/rules.d/85-hwclock.rules
Reading rules file: /etc/udev/rules.d/86-remoteproc-noroot.rules
Reading rules file: /etc/udev/rules.d/86-rpmsg-noroot.rules
Reading rules file: /etc/udev/rules.d/87-iio-noroot.rules
Reading rules file: /etc/udev/rules.d/88-leds-noroot.rules
Reading rules file: /usr/lib/udev/rules.d/90-libiio0.rules
Reading rules file: /usr/lib/udev/rules.d/95-dm-notify.rules
Reading rules file: /usr/lib/udev/rules.d/96-e2scrub.rules
Reading rules file: /usr/lib/udev/rules.d/97-hid2hci.rules
Reading rules file: /usr/lib/udev/rules.d/99-systemd.rules
Reading rules file: /etc/udev/rules.d/uio-pruss.rules
Reading rules file: /etc/udev/rules.d/uio.rules
sd-device: Failed to chase symlinks in "/devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/i2c-dev/i2c-0".
i2c-0: /etc/udev/rules.d/10-of-symlink.rules:12 LINK 'bone/i2c/0'
i2c-0: /usr/lib/udev/rules.d/60-i2c-tools.rules:1 GROUP 109
i2c-0: /usr/lib/udev/rules.d/60-i2c-tools.rules:1 MODE 0660
i2c-0: /etc/udev/rules.d/80-i2c-noroot.rules:7 GROUP 996
i2c-0: /etc/udev/rules.d/80-i2c-noroot.rules:7 RUN '/bin/chgrp -R gpio '/sys%p''
i2c-0: /etc/udev/rules.d/80-i2c-noroot.rules:7 RUN '/bin/chmod -R g=u '/sys%p''
i2c-0: Preserve permissions of /dev/i2c-0, uid=0, gid=996, mode=0660
i2c-0: Failed to lock stack directory '/run/udev/links/bone\x2fi2c\x2f0': Permission denied
i2c-0: Failed to create/update device symlink '/dev/bone/i2c/0', ignoring: Permission denied
i2c-0: Failed to create symlink '/dev/char/89:0' to '/dev/i2c-0': Permission denied
i2c-0: Failed to create device symlink '/dev/char/89:0': Permission denied
DEVPATH=/devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/i2c-dev/i2c-0
DEVNAME=/dev/i2c-0
MAJOR=89
MINOR=0
ACTION=add
SUBSYSTEM=i2c-dev
OF_SYMLINK=bone/i2c/0
TAGS=:systemd:
CURRENT_TAGS=:systemd:
SYSTEMD_ALIAS=/dev/bone/i2c/0
DEVLINKS=/dev/bone/i2c/0
run: '/bin/chgrp -R gpio '/sys/devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/i2c-dev/i2c-0''
run: '/bin/chmod -R g=u '/sys/devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/i2c-dev/i2c-0''
Unload kernel module index.
Unloaded link configuration context.
It seems very similar to the output in my bookworm image:
tool version: 254
file size: 12589648 bytes
strings 2650688 bytes
nodes 9938880 bytes
Using default interface naming scheme 'v253'.
Skipping overridden file '/usr/lib/systemd/network/80-iwd.link'.
Skipping overridden file '/usr/lib/systemd/network/99-default.link'.
Skipping overridden file '/usr/lib/systemd/network/73-usb-net-by-mac.link'.
Skipping overridden file '/usr/lib/udev/rules.d/73-seat-late.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/90-libiio0.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/70-mouse.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/80-ifupdown.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-dmi-id.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-fido-id.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/64-btrfs-dm.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-persistent-storage-tape.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/75-net-description.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/73-special-net-names.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/95-dm-notify.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/70-uaccess.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/40-usb_modeswitch.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/90-console-setup.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-persistent-alsa.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/81-net-dhcp.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-sensor.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/78-sound-card.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-persistent-input.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-infiniband.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/97-hid2hci.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/80-net-setup-link.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/50-firmware.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-i2c-tools.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/80-debian-compat.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-cdrom_id.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-evdev.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-input-id.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-autosuspend.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/70-power-switch.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-persistent-v4l.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/70-memory.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/80-drivers.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/85-hwclock.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-block.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-persistent-storage-dm.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/90-iocost.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/70-joystick.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-drm.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-serial.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/50-udev-default.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/60-persistent-storage.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/64-btrfs-zoned.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/64-btrfs.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/55-dm.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/71-seat.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/99-systemd.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/70-touchpad.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/75-probe_mtd.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/96-e2scrub.rules'.
Skipping overridden file '/usr/lib/udev/rules.d/70-camera.rules'.
Reading rules file: /usr/lib/udev/rules.d/60-dmi-id.rules
Reading rules file: /usr/lib/udev/rules.d/90-console-setup.rules
Reading rules file: /usr/lib/udev/rules.d/90-iocost.rules
i2c-0: /etc/udev/rules.d/10-of-symlink.rules:12 Added SYMLINK 'bone/i2c/0'
i2c-0: Failed to create lock file for stack directory '/run/udev/links/bone\x2fi2c\x2f0': Permission denied
DEVNAME=/dev/i2c-0
MAJOR=89
MINOR=0
ACTION=add
TAGS=:systemd:
SUBSYSTEM=i2c-dev
This is the output from the buster image with 4.19 kernel:
Load module index
Network interface NamePolicy= disabled on kernel command line, ignoring.
Parsed configuration file /usr/lib/systemd/network/99-default.link
Reading rules file: /etc/udev/rules.d/50-hidraw.rules
Reading rules file: /etc/udev/rules.d/50-spi.rules
Reading rules file: /usr/lib/udev/rules.d/56-lvm.rules
Reading rules file: /usr/lib/udev/rules.d/60-bluealsa.rules
Reading rules file: /usr/lib/udev/rules.d/60-crda.rules
Reading rules file: /etc/udev/rules.d/60-omap-tty.rules
Reading rules file: /usr/lib/udev/rules.d/69-lvm-metad.rules
Reading rules file: /usr/lib/udev/rules.d/73-usb-net-by-mac.rules
Reading rules file: /etc/udev/rules.d/80-eeprom-noroot.rules
Reading rules file: /etc/udev/rules.d/83-eqep-noroot.rules
Reading rules file: /usr/lib/udev/rules.d/85-regulatory.rules
Reading rules file: /usr/lib/udev/rules.d/89-alsa-ucm.rules
Reading rules file: /usr/lib/udev/rules.d/90-alsa-restore.rules
Reading rules file: /usr/lib/udev/rules.d/90-usbmount.rules
Reading rules file: /etc/udev/rules.d/99-cpu-dma-latency.rules
Reading rules file: /etc/udev/rules.d/tisdk.rules
Rules contain 49152 bytes tokens (4096 * 12 bytes), 19192 bytes strings
4340 strings (48729 bytes), 3108 de-duplicated (30770 bytes), 1233 trie nodes used
Invalid inotify descriptor.
DEVPATH=/devices/platform/ocp/44e0b000.i2c/i2c-0/i2c-dev/i2c-0
DEVNAME=/dev/i2c-0
MAJOR=89
MINOR=0
ACTION=add
SUBSYSTEM=i2c-dev
USEC_INITIALIZED=107118489
run: '/bin/chgrp -R gpio '/sys/devices/platform/ocp/44e0b000.i2c/i2c-0/i2c-dev/i2c-0''
run: '/bin/chmod -R g=u '/sys/devices/platform/ocp/44e0b000.i2c/i2c-0/i2c-dev/i2c-0''
Unload module index
