Dear all,
I have written a dts and generated a dtbo file which allows to have an event1 on a GPIO pin when a button is pushed.
I also have written the C code to see when the button is pushed and…if I try to push the button, I can see that the event is caught.
However, if I push the button and then I start my C program, the event is not seen.
This is because the trigger is on transitions and not on logic levels.
Now I would like to have the trigger on logic level in such a way I can see the pushed button even if it is pushed before starting the C program.
However, I have not seen in the device tree documentation something about it.
I suppose the lines interested should be:
debounce_interval = <.....>;
linux,code = <....>;
gpios = <&gpioX ... ....>;
gpio-key,wakeup;
in particular
Do you have informations about it?
Thanks a lot.
Cheers.
Alberto
