Hi Robert,
I am new to BeagleBone. Right now I am stuck up in the intial phase of using
SPI0 (once I am able to use SPI0, I would go for SPI1). I tried to run the
command for installing device tree compiler, but prompted "bash: dtc not
found"I have on my BBB :
Linux arm 3.8.13xenomai-bone28.1 #1 SMP Thu Nov 21 09:53:58 CET 2013 armv7l
armv7l armv7l GNU/Linux
lots of bugs have been fixed since bone28...
And when I tried to install the dtc by sudo apt-get install dtc, it does not
work and gave error like:Err http://security.ubuntu.com precise-security/universe Translation-en
Something wicked happened resolving 'security.ubuntu.com:http' (-11 -
System error)
why do you have "security.ubuntu.com" enabled in /etc/apt/sources.list
? there is no armhf binaries on that server...
the same error appear when I used apt-get install for other packages.
I googled the error and accordingly two solutions:
1)
xfce - How do I set system-wide proxy servers in Xubuntu, Lubuntu or Ubuntu Studio? - Ask UbuntuI did what is asked for but still the same results. I want to tell that for
checking if my BBB has proxy I used the following commandenv | grep -i proxy
Nothing got printed with this command (so there is no proxy) to from the
link above I only used the lines
no_proxy="localhost,127.0.0.1,localaddress,.localdomain.com"
NO_PROXY="localhost,127.0.0.1,localaddress,.localdomain.com"But I have a doubt since BBB device connect to PC via USB and when I use a
site to find my proxy it gives some IP, but when I used the command "env |
grep -i proxy". It does not print anything. I need your suggestion.2) I added these two lines in the file /etc/resolvconf/resolv.conf.d/tail
nameserver 8.8.8.8
nameserver 8.8.4.4and then sudo /etc/init.d/resolvconf restart
Still apt-get install does not work and gives the same error as
System error)I would be highly obliged if you would give some suggestions.
Remove security and try again.
