@RobertCNelson
Here is my overlay:
// SPDX-License-Identifier: GPL-2.0-only
* Copyright (C) 2023 IES Systems Inc.
* Ryan Robinson
* Virtual cape for IES custom cape 00
pinmux control byte map courtesy of https://beaglebone.cameon.net/
Bit 5: 1 - Input, 0 - Output
Bit 4: 1 - Pull up, 0 - Pull down
Bit 3: 1 - Pull disabled, 0 - Pull enabled
Bit 2 \
Bit 1 |- Mode
Bit 0 /
/dts-v1/;
/plugin/;
#include <dt-bindings/board/am335x-bbw-bbb-base.h>
#include <dt-bindings/pinctrl/am33xx.h>
* Helper to show loaded overlays under: /proc/device-tree/chosen/overlays/
&{/chosen} {
overlays {
IES-CAPE = __TIMESTAMP__;
* Free up the pins used by the cape from the pinmux helpers.
&ocp {
P8_11_pinmux { status = "disabled"; }; /* P8_11: qep2_B */
P8_12_pinmux { status = "disabled"; }; /* P8_12: qep2_A */
P8_13_pinmux { status = "disabled"; }; /* P8_13: hrpwm2B */
P8_15_pinmux { status = "disabled"; }; /* P8_15: qep2_strobe */
P8_16_pinmux { status = "disabled"; }; /* P8_16: qep2_index */
P8_19_pinmux { status = "disabled"; }; /* P8_19: hrpwm2A */
P9_11_pinmux { status = "disabled"; }; /* P9_11: uart4_rxd */
P9_12_pinmux { status = "disabled"; }; /* P9_12: gpio - DE/RE_ */
P9_13_pinmux { status = "disabled"; }; /* P9_13: uart4_txd */
P9_14_pinmux { status = "disabled"; }; /* P9_14: hrpwm1A */
P9_16_pinmux { status = "disabled"; }; /* P9_16: hrpwm1B */
P9_17_pinmux { status = "disabled"; }; /* P9_17: spi0_cs0 */
P9_18_pinmux { status = "disabled"; }; /* P9_18: spi0_d1 */
P9_19_pinmux { status = "disabled"; }; /* P9_19: i2c2_scl */
P9_20_pinmux { status = "disabled"; }; /* P9_20: i2c2_sda */
P9_21_pinmux { status = "disabled"; }; /* P9_21: spi0_d0 */
P9_22_pinmux { status = "disabled"; }; /* P9_22: spi0_sclk */
P9_23_pinmux { status = "disabled"; }; /* P9_23: gpio - DE/RE_ */
P9_24_pinmux { status = "disabled"; }; /* P9_24: uart1_txd */
P9_25_pinmux { status = "disabled"; }; /* P9_25: qep0_strobe */
P9_26_pinmux { status = "disabled"; }; /* P9_26: uart1_rxd */
P9_27_pinmux { status = "disabled"; }; /* P9_27: qep0_B */
P9_41_pinmux { status = "disabled"; }; /* P9_42: qep0_index */
P9_42_pinmux { status = "disabled"; }; /* P9_42: qep0_A */
P9_92_pinmux { status = "disabled"; }; /* P9_92: GPIO3_18 = EQEP0A_in */
P9_91_pinmux { status = "disabled"; }; /* P9_91: GPIO3_20 = EQEP0_index */
&am33xx_pinmux {
mux_helper_pins: pins {
pinctrl-single,pins = <
/* EHRPWM1 */
BONE_P9_14 0x6 /* P9_14 | MODE 6 */
BONE_P9_16 0x6 /* P9_16 | MODE 6 */
/* EHRPWM2 */
BONE_P8_19 0x4 /* P8_19 | MODE 4 */
BONE_P8_13 0x4 /* P8_13 | MODE 4 */
/* UART1 */
AM33XX_PADCONF(AM335X_PIN_UART1_TXD, PIN_OUTPUT, MUX_MODE0) /* P9_24 uart1_txd.uart1_txd */
AM33XX_PADCONF(AM335X_PIN_UART1_RXD, PIN_INPUT, MUX_MODE0) /* P9_26 uart1_rxd.uart1_rxd */
/* UART4 */
AM33XX_PADCONF(AM335X_PIN_GPMC_WPN, PIN_OUTPUT, MUX_MODE6) /* P9_13 gpmc_wpn.uart4_txd_mux2 */
AM33XX_PADCONF(AM335X_PIN_GPMC_WAIT0, PIN_INPUT, MUX_MODE6) /* P9_13 gpmc_wait0.uart4_rxd_mux2 */
/* I2C2 */
BONE_P9_20 0x73 /* i2c2_sda, SLEWCTRL_SLOW | INPUT_PULLUP | MODE3 */
BONE_P9_19 0x73 /* i2c2_scl, SLEWCTRL_SLOW | INPUT_PULLUP | MODE3 */
/* SPI0 */
BONE_P9_17 0x20 /* spi0_cs0, INPUT MODE0 */
BONE_P9_18 0x20 /* spi0_d1, INPUT MODE0 */
BONE_P9_21 0x20 /* spi0_d0, INPUT MODE0 */
BONE_P9_22 0x20 /* spi0_sclk, INPUT MODE0 */
/* EQEP0 */
BONE_P9_42B 0x31 /* P9_42,EQEP0A, MODE1 */
BONE_P9_27 0x31 /* P9_27,EQEP0B, MODE1 */
BONE_P9_25 0x31 /* P9_25,EQEP0strobe_in, MODE1 */
BONE_P9_41B 0x31 /* P9_41,EQEP0index_in, MODE1 */
/* EQEP2 */
BONE_P8_12 0x34 /* P8_12,EQEP2A_in, MODE4 */
BONE_P8_11 0x34 /* P8_11,EQEP2B_in, MODE4 */
BONE_P8_15 0x34 /* P8_15,EQEP2strobe_in, MODE4 */
BONE_P8_16 0x34 /* P8_16,EQEP2index_in, MODE4 */
/* GPIO Outputs */
BONE_P9_12 0x0f /* Mode 7: GPIO Output - COM1 DE/RE_ */
BONE_P9_23 0x0f /* Mode 7: GPIO Output - COM2 DE/RE_ */
&ocp {
test_helper: helper {
compatible = "bone-pinmux-helper";
pinctrl-names = "default";
pinctrl-0 = <&mux_helper_pins>;
status = "okay";
&uart1 {
/* sudo agetty 115200 ttyS1 */
status = "okay";
&uart4 {
/* sudo agetty 115200 ttyS4 */
status = "okay";
&i2c2 {
status = "okay";
/* this is the configuration part */
clock-frequency = <100000>; // Standard speed for testing.
#address-cells = <1>;
#size-cells = <0>;
&eqep0 {
count_mode = <0>; // count_mode is not userspace op_mode
// 0 -> Quadrature mode, normal 90 phase offset cha & chb.
// 1 -> Direction mode. cha input = clock, chb input = direction
// 2 -> UP count mode for frequency measurement QDIR=1, ignore direction input
// 3 -> DOWN count mode for frequency measurement QDIR=0, ignore direction input
swap_inputs = <0>; // swap channel A and B? (0 - no, 1 - yes)
invert_qa = <0>; // invert channel A input?
invert_qb = <0>; // invert channel B input?
invert_qi = <0>; // invert index input?
invert_qs = <0>; // invert strobe input?
omit_interrupt = <1>; // 1 -> do not install interrupt handler, 0 -> do install
status = "okay";
&eqep2 {
status = "okay";
&epwmss0 {
status = "okay";
&epwmss1 {
status = "okay";
&ehrpwm1 {
status = "okay";
&epwmss2 {
status = "okay";
&ehrpwm2 {
status = "okay";
&spi0 {
status = "okay";
#size-cells = <0>;
* Select the D0 pin as output and D1 as
* input. The default is D0 as input and
* D1 as output.
//ti,pindir-d0-out-d1-in;
channel@0 {
#size-cells = <0>;
compatible = "spidev";
symlink = "bone/spi/0.0";
reg = <0>;
spi-max-frequency = <16000000>;
spi-cpha;
channel@1 {
#size-cells = <0>;
symlink = "bone/spi/0.1";
reg = <1>;
Where would I find the gpio-pin address? Do you mean the “BONE_X_Y” constants I use? I get those from the included headers, so I would think they are ok.
