Getting started a pwm-control I recognized /dev/bone/,empty. uEnv.txt is checked and seems pretty, but no loading of overlays during startup.
serial console shows:
U-Boot 2022.04-g5509547b (Jan 22 2026 - 19:56:08 +0000)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
Reset Source: Global warm SW reset has occurred.
RTC 32KCLK Source: External.
Core: 150 devices, 14 uclasses, devicetree: separate
WDT: Started wdt@44e35000 with servicing (60s timeout)
Loading Environment from EXT4…
\*\* Unable to use mmc 0:1 for loading the env \*\*
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=\[A335BNLT\] …
board_rev=\[00C0\] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Couldn’t find partition 0:2 0x82000000
Can’t set block device
Scanning mmc 0:1…
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk…
Scanning disk mmc@481d8000.blk…
Found 7 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt …
Checking for: /boot/uEnv.txt …
2106 bytes read in 4 ms (513.7 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-6.12.32-bone28 …
8466944 bytes read in 540 ms (15 MiB/s)
debug: \[enable_uboot_overlays=\] …
loading /boot/dtbs/6.12.32-bone28/am335x-boneblack.dtb …
99479 bytes read in 12 ms (7.9 MiB/s)
uboot_overlays: add \[enable_uboot_overlays=1\] to /boot/uEnv.txt to enable…
loading /boot/initrd.img-6.12.32-bone28 …
8498283 bytes read in 543 ms (14.9 MiB/s)
debug: \[console=ttyS0,115200n8 root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 root=UUID=38b2f07f-3be6-4.
debug: \[bootz 0x82000000 0x88080000:81ac6b 0x88000000\] …
Kernel image @ 0x82000000 \[ 0x000000 - 0x813200 \]
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f7e5000, end 8ffffc6b … OK
Loading Device Tree to 8f7c9000, end 8f7e4496 … OK
Starting kernel …
\[ 0.000000\] Booting Linux on physical CPU 0x0
Kernel is
Linux domus 6.12.32-bone28 #1 PREEMPT Thu Jun 5 22:59:34 UTC 2025 armv7l GNU/Linux
Best regards
