Devkit8000 and usb otg
Hi
I have a devkit8000, one from the first generation, 128mb, no usb
host. therefor I'd like to use the usb otg port. I remember it worked
with certain revision of .32 or .33 kernel but then it stopped
working. lsusb doesn't show anything. also there's no /sys/devices/
platform/musb* . has anyone made similar experience or has someone
even a solution? I've tried several kernel releases from the devkit8k
sources on gitorious up to the most recent one with different configs.
maybe I miss a important option...
thanks in advance
martin
Hello Martin,
can you send your .config please.
Thomas
Hi Thomas
as the whole config is quite long, I've put it in a pastebin:
http://dpaste.org/OFZO/
does the otg work on your board? it is only a first rev issue?
cheers
Hello Martin,
is the plug in of the mini-usb connector on your board detected?
[ 126.875854] twl4030_usb twl4030_usb: HW_CONDITIONS 0xc0/192; link 1
[ 126.878967] twl4030_usb twl4030_usb: twl4030_phy_resume
yes if I plug out plug in at the board I get the kernel msg you
described ^. If I do it at the hub nothing happens
/martin
