I have had wireless working on a 3.8 BBB for quite some time and I wanted to move to a v4 kernel in the hope that the “lagginess” of the wifi connection would be reduced. I loaded another board with the LTS RT v4 kernel, did apt-get install wireless-tools wireless-regdb crda, and put my ssid and passphrase in /etc/network/interfaces. The results are:
root@beaglebone:~# ifup -vv wlan0
Configuring interface wlan0=wlan0 (inet)
run-parts --exit-on-error --verbose /etc/network/if-pre-up.d
run-parts: executing /etc/network/if-pre-up.d/wireless-tools
dhclient -v -pf /run/dhclient.wlan0.pid -lf /var/lib/dhcp/dhclient.wlan0.leases wlan0
Internet Systems Consortium DHCP Client 4.3.1
Copyright 2004-2014 Internet Systems Consortium.
All rights reserved.
For info, please visit ISC DHCP - ISC
Listening on LPF/wlan0/c4:6e:1f:10:0e:70
Sending on LPF/wlan0/c4:6e:1f:10:0e:70
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 16
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
I must have missed something. I even copied the interfaces file over from the 3.8 machine, but no joy. Of course, I also went from Wheezy to Jessie.
The hardware is a TP-Link WN722N (Atheros) that I haven’t had any problems with - in fact it does an “iwlist wlan0 scan” just fine in the new machine. This seems to a software problem.
It is interesting that even after installing crda and wireless-regdb, dmesg shows:
[ 10.512066] ath: EEPROM indicates we should expect a country code
[ 10.512073] ath: doing EEPROM country->regdmn map search
[ 10.512079] ath: country maps to regdmn code: 0x52
[ 10.512085] ath: Country alpha2 being used: CN
[ 10.512090] ath: Regpair used: 0x52
[ 10.552110] ieee80211 phy0: Atheros AR9271 Rev:1
[ 10.638305] cfg80211: Regulatory domain changed to country: CN
To be complete, ifconfig shows:
wlan0 Link encap:Ethernet HWaddr c4:6e:1f:10:0e:70
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
and iwconfig wlan0 shows:
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
and this is the interfaces file:
auto wlan0
iface wlan0 inet dhcp
wpa-ssid “my_ssid”
wpa-psk “my_passphrase”
I would appreciate any help that you can provide,
Tim
