Difference between -ti and bone* kernel?
Hello all,
I’ve noticed some bad HDMI jitter/flickering when using the -bone kernel, which is present both in 3.14 and latest 4.1. However this flickering is not present when using the -ti kernel, regardless of the version; the -ti version is used by default in rcn’s netinstall script. Unfortunately, building sgx modules fails with the -ti kernel (“error: implicit declaration of function fb2display”) but works fine, using the same SDK, when using -bone kernel as compiled with rcn’s bb-kernel repo (branch am33x-3.14).
Therefore I’m wondering what is ultimately the difference between those two (isn’t it a waste of effort to maintain two separate kernels?), and if any of you had a solution for this build issue. Hopefully I’d like to use the kernel with the least bugs, which seems to be -ti so far regarding HDMI. Nonetheless I’d like to thank Robert C. Nelson for his work and in particular the very useful netinstall/bb-kernel repos.
Best regards,
Tziang
Hello all,
I've noticed some bad HDMI jitter/flickering when using the -bone kernel,
version is used by default in rcn's netinstall script. Unfortunately,
building sgx modules fails with the -ti kernel ("error: implicit
declaration of function fb2display") but works fine, using the same SDK,
when using -bone kernel as compiled with rcn's bb-kernel repo (branch
am33x-3.14).
"flickering" should be gone in am33x-4.4+ as tilcdc patches went mainline a
couple months back and i back ported it..
Therefore I'm wondering what is ultimately the difference between those
two (isn't it a waste of effort to maintain two separate kernels?), and if
any of you had a solution for this build issue. Hopefully I'd like to use
HDMI. Nonetheless I'd like to thank Robert C. Nelson for his work and in
It's only a mess right now, as we have a couple transitions in flight..
uio_pruss -> remoteproc_pruss
old_sgx_drivers -> new_sgx_drivers
A lot of users, use uio_pruss and the old_sgx_drivers, thus they are
currently stuck in the "bone" kernel's..
at some point, remoteproc_pruss will fulfill uio_pruss users needs (and
also go mainline), thus solving that problem..
sgx = no comment...
sgx = no comment…
heh yeah, it’s only been 3 years TI . . .just for the beaglebone black platform.
Robert, TI kernel still has usable power management ? Or is this no longer a difference between the two ?
v4.1.x-ti has the best..
v4.4.x-bone & v4.4.x-ti are about the exact same.. (at the moment)
at idle:
  current CPU frequency is 300 MHz (asserted by call to hardware).
  cpufreq stats: 300 MHz:60.64%, 600 MHz:2.75%, 800 MHz:0.00%, 1000
MHz:36.60% (14)
root@beaglebone:~# uname -r
4.4.8-ti-r22
5v @ 0.15~0.18 Amps on my jumpy power supply...
echo mem > /sys/power/state
5v @ 0.05 Amps
bbb: rev a5a, just a ftdi serial cape attached..
OK cool. I’m still wanting to stick with 4.1.xbone but since for the given project I’m working on I do not need uio_pruss - Maybe I’ll use the TI kernel instead.
I had also noticed in the past that the TI kernels used slightly less memory at boot too. But only because the bone kernel was creating a few smallish ramdisk’s at boot. I think the difference was only a few Megabytes of used RAM.
Thanks Robert :slight_smile:
Hello Robert,
Thanks for the fast reply. I’m unsure what you mean by “sgx = no comment”. Is sgx no longer officially supported by TI?
Also I would like to provide more light about my building issues with the stock Graphics SDK provided by TI:
  • issue 1: “error: implicit declaration of function fb2display” occurred because I forgot to add TI_PLATFORM=ti335x. The complete command line is
    make GRAPHICS_INSTALL_DIR=/home/tzsw/Graphics_SDK_5_01_01_02 KERNEL_INSTALL_DIR=/home/tzsw/ti-linux-kernel BUILD=release OMAPES=8.x FBDEV=yes TI_PLATFORM=ti335x all
  • issue 2: “fatal error: omapfb/omapfb.h: No such file or directory” is a known issue with the TI Graphics SDK. Does TI not test its SDK against its kernel? Robert C Nelson’s ti-sdk-pvr repository on github has the fix, in particular the 5.01.01.01-ti branch: https://github.com/RobertCNelson/ti-sdk-pvr/commits/5.01.01.01-ti
Tziang
