Sorry for the noob question, but I can’t find the answer by googling…
What’s the difference between compiling for ‘arm’ and ‘armv7l’ architectures? Both can run in a beagleboard C4?
Thanks in advance for your help
best regards,
Pedro Ignacio Martos
'arm' is not specific enough, see "march":
http://gcc.gnu.org/onlinedocs/gcc-4.7.0/gcc/ARM-Options.html#ARM-Options
'armv7l' ('armv7' is the Architecture of the core, 'l' don't
remember..) is just the kernel machine name, for a cortex-ax class
device such as the beagle (cortex-a8), you'd use "-march=armv7-a" with
gcc..
Thanks for the response; some context for the question: I am playing with a beagleboard C4 and ubuntu. In 12.04 there is out of the box support for my wifi dongle (rtl8192cu); but in 11.10 the module exists, but it doesn't work with my wifi dongle, so I tried to recompile the driver from rtl.
I am following the instructions here (https://groups.google.com/forum/?fromgroups#!topic/beagleboard/5xMAyFxQbdE); and it says that I need to touch the makefile and put "ARCH = arm"(and not "armv7l"). I also followed the instrucctions here (http://lakm.us/logit/2012/01/compile-usb-serial-modem-using-option-c-ubuntu-on-beagleboard-xm/). And it says that it's necessary to install the linux headers and the linux image .deb packages. When I installed the image package, I discovered that the kernel changed from "arm" to "armv7l" in uname, so I am looking for the difference between being "arm" and "armv7l". Any information will be appreciated
best regards,
Ignacio
"armv7l").
In that case, by using "ARCH=arm" your selecting ARM subarch of the
linux kernel...
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git;a=blob;f=Makefile;hb=HEAD#l195
Instead of touching the makefile, just run "make ARCH=arm <...>"
appreciated
Are you sure about that? It should have been armv7l to begin with,
unless someone patched the kernel oddly..
linux kernel...
Thanks, I didn't thought on that.
It seems that I touched something by mistake, I did a full reinstall (reflashing the sdcard from the image) and uname -a now says armv7l, sorry.
