Difficulty in accessing the GPIO (Mikrobus Beagle Play Board)
Hi Team,
I am not able to access the GPIO of my Mikrobus.
I have followed the step mention in the document.
When I am running the command ----> dmesg | grep mikrobus
[ 2.096254] mikrobus:mikrobus_port_register: registering port mikrobus-0
[ 2.096325] mikrobus mikrobus-0: mikrobus port 0 eeprom empty probing default eeprom
I am not getting result like mentioned in the document.
Also for ls /dev/play command. I am getting only
grove qwiic
I am not getting mikrobus folder. It will create problem?
Please guide me. I am new into linux as well as for the beagle/mikrobus related board.
Regards
Manan
Please post a link to the doc you are referring too so we can be on the same page as you.
I am referring below link.
https://docs.beagleboard.org/latest/boards/beagleplay/demos-and-tutorials/using-mikrobus.html#beagleplay-mikrobus
But I am not getting expected output as they are following.
Please I need support
What output are you getting?
I just looked at the docs, are you using a Mikrobus board? If so, per the docs it should identify itself and load the correct files.
