I have a BeagleBone Black. It is running a Debian 8.2 flasher image from December 2015. I want to free resources by pruning the running config a bit, but its not clear to me how to do so.
I was able to locate one question on running web servers at:
The BBB seems to be different even though its running a Debian image, so I don’t want to risk breaking the configuration. My apologies if I missed a discussion of the topic.
[snip]
How do I stop the following services:
* web related services, like Apache
* sound related services, like Avahi
* windows managers, like LXDE
The (fairly) obvious way to do this is simply to uninstall them:-
apt-get remove apache2
(you need to be root or prefix with 'sudo').
It's easy enough, if you want them back at some later date, to
re-install them. You may have to work out the full package names to
use with 'apt-get remove'. You can either use 'apt-cache search' or
'dpkg -l | grep <name>'.
This keeps apache from starting a boot time, but it also makes it easy to undo the change by simply moving apache2 out of the hide folder if you want it to start again.
