Display resolution on boot on Beaglebone AI-64
I have display resolution issues when using the Beaglebone AI-64 on my 4k monitor.
When I finally finally get the monitor to the Display Port the resolution looks like a PC XT resolution.
Is there a way to tell the debian boot to mind its own business and always set the correct resolution and not assume that I am using the cheapest display available?
The monitor is a 4k 32 inch monitor which I use normally with my mac Studio M2 on the HDMI1 port.
I didn’t find any way to impose a display size like I do on my ArchLinux or MAC.
On ArchLinux I change the display to a slightly lower resolution, it is not possible on that debian, I have to change the DPI
The default when it identifies the display is text that is so small to be unreadable.
Michel
I found some easily found commands to test and change resolution…on the fly (may be more difficult than how I am stating things…).
xdpyinfo | grep 'dimensions:'
The above command will show your actual pixelated formatted dimension(s)…
If you have a graphics card, I am out. I know way too little so far about the graphics on the TDA4VM.
But…when in doubt:
inxi -G
That inxi -G command will output some valuable data about the GPU if accessible…
P.S. Good luck!
Oh!
also…
% man xrandr
$ man xdpyinfo
Those commands will show you some pretty deep articles on each, separate command and the usage behind them. I have not fully or successfully attached any resolution monitor (recently) to the BBAI-64.
I had one Mac Monitor attached but my personal connection was iffy. I could not get more into it at the time. The Mac Monitor is now gone…so. Yea, I am out on resolution games for now.
Also…
# This is all from nixCraft online
xrandr -s <size>/<width>x<height>
So, something like this may help:
xrandr --size 1366x768 && xrandr --listmonitors
Then, to handle the exchange in formatting:
xrandr --setmonitor eDP-1-1 --size 2560x1440
But I suggest a reasonable skim or good read of the man pages.
So one of the issues on the AI-64, is the cadence firmware for the displayport ip… On initial startup, this won’t be available till late in the boot-up. Now the other issue could be using 5.10.x, vs 6.1.x/6.6.x/mainline…
