I need to use DMA in my projects. After i generate my DMA buffer
and obtain datas into this buffer, i wonder, is there an interrupt
that inform or alert me when DMA buffer is full ( or when DMA buffer
over 32 bytes). I know there are some counters on DMA but i dont want
to check them in while. Any suggestion?
I'd have to look at my code, but I think there is a call back you can
register that is called when a DMA completes. I know what you want is
possible, because I have such code in a a driver I wrote
Then i am waiting for your code Could be set the interrupt to be
generated for specific amount of data or interrupt is only generated
when the buffer is full? Which one did you mean?
When I request the dma channel, I register the callback:
if (omap_request_dma(OMAP_DMA_NO_DEVICE, "usrp-e-rx",
usrp_rx_dma_irq, (void *) rx_dma, &rx_dma->ch)) {
