DMTimer symbols not found
Hi All,
I am trying to write a kernel module that uses the Beagle Bone Black’s DMTimer to capture the trigger time of an input signal. When I try to install the kernel module, I receive the following errors:
[420546.913700] dmtimer_query: Unknown symbol omap_dm_timer_request_specific (err 0)
[422324.347351] dmtimer_query: Unknown symbol omap_dm_timer_stop (err 0)
It looks like my kernel version is not compiled with DMTimer support. I am using kernel “4.1.11-bone-rt-r16”. Would my problem be solved by switching to another precompiled kernel? If so, which kernel should I use? Do I need to recompile the linux kernel to include DMTimer support?
Thank you for the assistance,
Adam
Well it's built-in..
CONFIG_OMAP_DM_TIMER=y
https://github.com/RobertCNelson/linux-stable-rcn-ee/blob/dcf1a51fe776d3be58e7f663b65cbbf40a69e42d/arch/arm/configs/rcn-ee_defconfig#L380
So maybe rebuild as a module?
Hi All,
Thank you for the insight. You are right, the kernel did have the omap_dm_timer symbols.
My error was that the symbols I required were exported as EXPORT_SYMBOL_GPL and I had not declared it as my license as MODULE_LICENSE(“GPL”) in my kernel module. As a result, my kernel module was not allowed to use those function symbols.
Cheers,
Adam
