Do I really need a USB-to-FTDI cable to see the U-boot prompt? Will it not work on micro-HDMI?
Hi, I’ve seen some docs on how to build a custom kernel and so far it appears to have cross-compiled correctly.
http://elinux.org/Building_BBB_Kernel
http://elinux.org/Beagleboard:BeagleBone_Black_Serial
Now, in order to see the U-boot prompt, it says I should connect the serial cable to my PC. I currently don’t have a FTDI cable and buying one is going to be a slow, bureaucratic process (company policies, employment status as a contractor, blah blah blah). I was wondering if it is really needed - I have a micro-HDMI and a USB keyboard, I can access the Linux console with them. Can they be used to access the U-boot prompt and command line?
(Sorry if it sounds like a dumb question but I’d never heard of U-boot before. I’ve worked with other similar devices but they had an Intel processor and chipset, was able to access EFI and GRUB via HDMI).
The BBB also had a mini-USB cable included. By plugging it to my PC with it I can see the BBB as a storage device and it shows up the first partition of eMMC (docs, drivers, etc). But it doesn’t appear to expose a serial port and so I don’t think I can use it to see the boot prompt…is that correct?
Thanks.
Hi, I've seen some docs on how to build a custom kernel and so far it
Building BBB Kernel - eLinux.org
Beagleboard:BeagleBone Black Serial - eLinux.org
cable to my PC. I currently don't have a FTDI cable and buying one is going
Serial only...
(Sorry if it sounds like a dumb question but I'd never heard of U-boot
before. I've worked with other similar devices but they had an Intel
eMMC (docs, drivers, etc). But it doesn't appear to expose a serial port and
so I don't think I can use it to see the boot prompt...is that correct?
You do not have to buy a FTDI cable. It could be any decent cable, that does not necessarily cost as much as FTDI. For example my buddy and I ordered a couple of PL2303HX cables off ebay for like $5-6 usd shipped.
My point here is that you could just simply pay $2-$3 out of your pocket, and just be done with it. However, depending on who you deal with shipping can take a long time . . .
The ones I found with shipping (to Canada) were in the $40-50 range, which was discouraging – more expensive than buying a new BeagleBone! Eventually found this one on Amazon for $3, including shipping, and it works great:
https://www.amazon.ca/gp/product/B00F167PWE
Stéphane
