Does anyone have a CUPS 1.4.x recipe?
I've been trying to build CUPS 1.4.2 and 1.4.3 on the OE unstable
branch which seems to work fine after tweaking the recipes for 1.3.8
slightly. The cupsd daemon segfaults instantly however, and I'm having
some trouble debugging the cause.
Before I spend more time trying to get to the bottom of this, has
anyone been able to successfully build and run CUPS 1.4.x on the BB
and have a recipe they could share?
Cheers,
Dear Tarjei,
If I were you, it would contact the openembedded-devel list and send
them a patch with your already accomplished work.
Good luck,
Paul
Thanks for the pointer Frank. Posted to the oe-dev list, but finally
figured it out myself in the end. Seems like the Beagle is not too
happy with -fPIE and -fstack-protector.
I'm attaching the final recipe to this post in case anyone else needs it.
cups-1.4.3-recipe.tar.gz (2.98 KB)
Ahem... s/Frank/Paul/g :slight_smile:
