I’ve a pair of Beaglebone Greens, one running “latest” from beagleboard.org image 2015-11-12 kernel 3.8.13-bone79, the other running what came loaded in the eMMC: 2015-03-01 kernel 3.8.13-bone71.1
Both are “current” with apt-get update ; apt-get upgrade as of a day or two ago. I’m having some BoneScript/Node-RED issues and noticed the 2015-11-12 image has BoneScript 0.2.5, whereas the 2015-03-01 has BoneScript 0.2.4
Is BoneScript not part of the “normal” apt-get update/upgrade maintenance?
I just did apt-get update/upgrade on the BoneScript 0.2.4 system before I post this message and I get:
W: Size of file /var/lib/apt/lists/security.debian.org_dists_wheezy_updates_main_binary-armhf_Packages.gz is not what the server reported 400377 400405
From the update, and the upgrade shows 5new packages, none of which appear to have anything to do with BoneScript.
The first BBG (with BS 0.2.5) I wanted to setup with an 8GB SD card and “standardize” with my BBW and BBB running Jessie, but I burned the “latest” Wheezy image to its eMMC when I tried some BoneScript stuff to help out a friend and had issues, and got an answer here that BoneScript was not working for 4.1 kernels yet so I should use 3.8 series if I want BoneScript.
I’m finding that most of the BoneScript examples have issues – throwing apparently harmless error messages, or just plain not working and throwing apparently fatal error messages. I’m beginning to doubt that BoneScript is a very useful starting point for a newbie (my friend).
For instance the blinkled.js example at: http://192.168.7.2:3000/ide.html
prints this in the examples/blinkled.js tab when I run it:
debugger listening on port 15454
/usr/local/lib/node_modules/bonescript/my.js:57
if(slot[0]) {
TypeError: Cannot read property ‘0’ of null
at Object.exports.load_dt (/usr/local/lib/node_modules/bonescript/my.js:57:20)
at Object.exports.create_dt (/usr/local/lib/node_modules/bonescript/my.js:123:33)
at Object.exports.setPinMode (/usr/local/lib/node_modules/bonescript/hw_capemgr.js:83:12)
at Object.f.pinMode (/usr/local/lib/node_modules/bonescript/index.js:160:15)
at Object. (/var/lib/cloud9/examples/blinkled.js:6:7)
at Module._compile (module.js:456:26)
at Object.Module._extensions…js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.runMain [as _onTimeout] (module.js:497:10)
