Does not match the target endianness error on beagleboard
hi all
i m using ccstudiov5 to debug beagleboard using xds100v2 jtag emulator.
i have used these settings
GEL : omap3530_cortexA.gel
Buid options: target : generic cortex-A8 processor
Device endianness :be32
output format:ELF
when i try to load the program
i m getting these errors…
Cortex_A8_0: GEL: File: C:\Users\Admin\omap_jtag_ccv5\helloworld1\Debug\helloworld1.out Does not match the target endianness, not loaded. Check project build options and target configuration file (ccxml).
i also use DM3730evm GEL file but same error appears.
ti e2e people are not responding… how can i resolve this issue ?
Hi there,
I believe the issue will be resolved by changing the parameters Device endianness: be32 to some value that represents little-endian
I would guess that it is pertaining to the storage on your device and it looks like beagleboard default build parameters use littleendianess. Thinking be32 is referring to Big-endian Fat 32 using similar notation you can try looking in the manual or try le32 (no grantees there)
Hope this helps
Husain
