DSP applications
http://ossie.wireless.vt.edu/trac/wiki/BeagleBoard_CodecEngine
I am trying to execute the GPP and DSP applications according to the
procedure given in above link. But the applications messagegpp,
ringio_gpp, mpcsxfergpp are crashing.
Is there anything that needs to be taken care of apart from the
steps given in above link?
Robin
./mpcsxfergpp /usr/share/ti-dsplink/cmd_compiled/DEBUG/mpcsxfer.out 1024
1000
========== Sample Application : [ 632.703613] Internal error: Oops -
undefinedT
[ 632.712463] Modules linked in: dsplinkk(F) nls_iso8859_1 ircomm_tty
ircomm i]
[ 632.722625] CPU: 0 Tainted: GF D (2.6.29-omap1 #2)
[ 632.728393] PC is at 0xc7e0be70
[ 632.731567] LR is at chrdev_open+0x1cc/0x1ec
[ 632.735870] pc : [<c7e0be70>] lr : [<c00c8f94>] psr: a0000013
[ 632.735900] sp : c7476118 ip : c7e0be30 fp : c780b240
[ 632.747436] r10: c7546318 r9 : c7e0a000 r8 : c7a7e740
[ 632.752685] r7 : c683f0e0 r6 : c7eb4a00 r5 : 00000000 r4 :
00000000
[ 632.759246] r3 : bf0ce000 r2 : c7e0a000 r1 : c7a7e740 r0 :
00000000
[ 632.765838] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM
Segment user
[ 632.773010] Control: 10c5387d Table: 86b48019 DAC: 00000015
����-��L��M�0 ����� (pid: -509603830, stack limit =
0xc74762e8)�S���S������
Hi Robin,
I also have had some problems. I could fix some of them, but there is one that I got stuck at, and it happens before your problem.
Do you had the same problem? If yes, how did you fix that?
Thanks in advance!
I am trying to execute the DSPlink, but when I do
bitbake ti-codec-engine
Well i did not the error doing "bitbake ti-codec-engine"
Looking into the contents of below file will give idea of the problem.
/home/karmonitor/oe/tmp/work/beagleboard-angstrom-linux-gnueabi/ti-dsplink-module-1613-r46a/temp/log.do_compile.5732
I have moved onto another link
http://elinux.org/BeagleBoard/DSP_Howto#Simplified
But i have not been able to get the v2.6.28-felipec1 kernel, looks like
its not available anymore.
Robin
Thanks Robin,
but with your information I could not solve my issues. I already saw the file /home/karmonitor/oe/tmp/work/
beagleboard-angstrom-linux-gnueabi/ti-dsplink-module-1613-r46a/temp/log.do_compile.5732. It is pointing the following error:
/bin/sh: /home/karmonitor/oe/tmp/staging/i686-linux/ti-cgt6x-native/bin/cl6x: No such file or directory
Checking my folder tree, I can see that /bin/c16x was not created. Should the makefile create this part? Is it a folder that I have to have?
I am working on it for 2 months.
Do you have some details that you used?
What unix distro did you use to build the DSPlink? Which version?
Thanks in advance.
Bruno Mendonça
2009/10/23 robinpv <robinpv@iwavesystems.com>
