Hi ALL,
I found tried to build dspbridge driver in "android-
omap-2.6.29-eclair kernel". "android-omap-2.6.29-eclair kernel" can be
downloaded from repostory:
http://android.git.kernel.org/?p=kernel/omap.git;a=summary
I have run $make menuconfig
and then enabled dspbridge driver as a module.
Then I tried to build the kernel using following command :
make -j4 modules CROSS_COMPILE=/media/EXTRA_SPACE/home/jitin/Documents/
tapas/arm-2007q3/bin/arm-none-linux-gnueabi- CC_PATH=/media/
EXTRA_SPACE/home/jitin/Documents/tapas/arm-2007q3/bin/arm-none-linux-
gnueabi-
But it gives errors and I failed to build dspbridge.ko as a module :
ers/dsp/bridge/services/kfile.o
CC [M] fs/isofs/joliet.o
CC [M] fs/isofs/compress.o
CC [M] net/dccp/ccids/lib/loss_interval.o
CC [M] drivers/dsp/bridge/services/sync.o
LD [M] fs/isofs/isofs.o
CC [M] drivers/dsp/bridge/services/clk.o
CC [M] fs/jffs2/compr.o
drivers/dsp/bridge/services/clk.c: In function 'SSI_Clk_Prepare':
drivers/dsp/bridge/services/clk.c:359: error: implicit declaration of
function 'IO_ADDRESS'
make[2]: *** [drivers/dsp/bridge/services/clk.o] Error 1
make[1]: *** [drivers/dsp/bridge] Error 2
make: *** [drivers] Error 2
make: *** Waiting for unfinished jobs....
CC [M] net/dccp/sysctl.o
CC [M] sound/pci/ice1712/delta.o
CC [M] fs/jffs2/dir.o
It seems to me clk.c file has some problem and dspbridge driver has
some problem. Can anyone help me to solve this problem?
