Hi Khasim,
I am a grad student working on implementing image processing algorithms on
beagle board.Up to now I have compiled OpenCV(OE ) and run face detection
application on beagle board. It took around 6 min to compute the
operations.Only choice left to me is to offload the programs to the DSP on
beagle board.I have done with .ping test but how can I build the Angstrom image including
DSP link using Open Embedded tool.
DSP Link is already integrated in OE, you should be able to use the
same. I am not sure if there is a opkg package install for the same.
Also, I suggest you to try default Angstrom image from Koen.
Suppose If I develop a DSP code(ie convolution using CC), how can I run it
on DSP from GPP application, I am confused from past one week could you
please help me with that.
See below links (courtesy chase maupin).
http://wiki.davincidsp.com/index.php/Example_application_using_DSP_Link_on_OMAPL1x
http://wiki.davincidsp.com/index.php/Example_DSPLIB/DSPLink_Application_on_OMAP-L1x
While these are for OMAP L 1x, the DSP side app integration should be similar.
Khasim
