i'm trying to get s-video working, are there any patch's for the
beagle board or commands that i need to enter to get it working or
links to info. Thanks!
This is the script I'm currently using with 2.6.29-oer44.1, It is
based off a script I found on a pandora related blog.
It works for NTSC timing, and gives output on both HDMI and S-Video in
clone/mirror mode.
[code]
# Detach console
echo "0" > /sys/class/vtconsole/vtcon1/bind
# Setup a new framebuffer (Important: this is 16 bit color
depth in RGB565 format and has a resolution which is supported by NTSC
timing!)
# Set NTSC resolution (with minimal overscan)
fbset -fb /dev/fb0 -bcast true -g 704 480 704 480 16 -rgba
5/11,6/5,5/0,0/0
# Just turn off everything so we have permission to change
anything
echo "0" > /sys/devices/platform/omapdss/display0/enabled
echo "0" > /sys/devices/platform/omapdss/display1/enabled
echo "0" > /sys/devices/platform/omapdss/overlay0/enabled
echo "0" > /sys/devices/platform/omapdss/overlay1/enabled
# Flush all writes
sync
# Before we can link overlay1 to fb0 we must unlink it from
fb1
echo "" > /sys/class/graphics/fb1/overlays
# Flush all writes
sync
# Link fb0 to overlay1 and overlay0
echo "1,0" > /sys/class/graphics/fb0/overlays
# Prepares the overlay size
echo "704,480" > /sys/devices/platform/omapdss/overlay1/
output_size
# Connect overlay1 to TV manager
echo "tv" > /sys/devices/platform/omapdss/overlay1/manager
echo "1" > /sys/devices/platform/omapdss/overlay1/enabled
# Set Displays to NTSC timing, not sure if the first line is
required
echo "ntsc" > /sys/devices/platform/omapdss/display0/timings
echo "ntsc" > /sys/devices/platform/omapdss/display1/timings
# Turn on overlay0 (DVI)
echo "1" > /sys/devices/platform/omapdss/overlay0/enabled
# Turn on the DVI Display
echo "1" > /sys/devices/platform/omapdss/display0/enabled
# Turn on overlay1 (TV)
# Turn on the TV Display
echo "1" > /sys/devices/platform/omapdss/display1/enabled
# Flush all writes
sync
[/code]
@GrizzlyAdams:
I appreciate your effort in posting the script here. But unfortunately
my region supports PAL settings, and I have tried to comprehend the
parameters & options in the script, but am unable to workaround a
hack. If its not much to ask for, could you point to or refer some
material to solve this issue ?
Thanks.
