Dual Display Capes
I plan on using Dual Display capes for my Project. The only query that I have is that since the 4DCAPE-70T LCD cape has provisions for additional capes using the additional headers, can another cape, say 4DCAPE-43T LCD, be connected to my BBB?
#Newbie
In general, as long as both displays are the same resolutions, timing, and size you can do that. There is only one LCD interface on the processor.
As to the capes, they have no top side connectors, because putting anything into top side connectors would cover up the display. Display capes are designed to be the last cape on the stack so they can be visible.
4DCAPE-70T: http://www.4dsystems.com.au/product/22/138/Beagle_Bone_LCD_Capes/4DCAPE_70/
DATASHEET: http://www.4dsystems.com.au/productpages/4DCAPE-70T/downloads/4DCAPE-70T_datasheet_R_1_1.pdf
4DCAPE-43T: http://www.4dsystems.com.au/product/22/125/Beagle_Bone_LCD_Capes/4DCAPE_43/
DATASHEET: http://www.4dsystems.com.au/new/productpages/4DCAPE-43/downloads/4DCAPE-43(T)_datasheet_R_1_8.pdf
These are the specific components I intend on using.
Regards.
Looking at this I see no way to hook one board into two different displays. There is one connector for the board on each panel. The board only has one set of connectors.
Why do you need two displays that have the same information displayed on both of them?
