So i recently got a samsung 331 hi def monitor with dvi connector just for the beagleboard. Much to my dismay, when plugged in it only displayed "mode not supported", which is listed in the manual as "Check the maximum resolution and connected device's Video frequency". I suspect that it is the frequency that is causing the problem, however i'm not sure what to do about it.
On the advice of some folks in chat i looked into updating xloader and uboot to the ones with the Angstrom demo, but i seemed to end up with the same problem(x-loader 1.4.2).
I suspect that it is an issue with the frequency, but am not really sure. More over if i got a different screen what frequency am i looking for?
for?
Anyone have any advice for getting it to work?
You need to replace the pre-flashed u-boot with e.g. the one from
OpenEmbedded/Angstrom and also use the OE omapfb patches. You can see
what timings are being used by dmesg | grep omapfb.
I've got the u-boot and x-loader from Angstrom here:
Now how do i "use the OE omapfb patches" and where might they be found?
Thanks for the tip on dmesg, i do indeed now see what it is set to. Are there other configurations available? I've managed to get bit-bake working for the Angstrom image, but am unclear on how to change settings such as this.
such as this.
What messages do you see?
I see:
root@beagleboard:/dev# dmesg | grep omapfb
omapfb: configured for panel omap3beagle
omapfb: DISPC version 3.0 initialized
omapfb: Framebuffer initialized. Total vram 1572864 planes 1
such as this.
I see:
omapfb: Pixclock 54000 kHz hfreq 45.6081 kHz vfreq 57.7 Hz
Nothing like "Using mode 1024x768@60"? If not, you're missing some
patches.
Which is indeed not supported by my monitor according to the manual
for it.
Most monitors seem to accept 57.7 Hz as an approximation of 60 Hz.
Maybe yours is extra picky.
FWIW, my Samsung TV has no trouble with 1280x720 at almost 60 Hz.
I see:
omapfb: configured for panel omap3beagle omapfb: DISPC version 3.0 initialized omapfb: Framebuffer initialized. Total vram 1572864 planes 1 omapfb: Pixclock 54000 kHz hfreq 45.6081 kHz vfreq 57.7 Hz
patches.
Nope, nothing like that. I am just using the demo images here:
I see:
patches.
Download it, rename it to ‘uImage’, and copy it to the DOS partition of your SD card. Then make sure your environment on the BB is set.
From the BB bootloader, type:
Download it, rename it to 'uImage', and copy it to the DOS partition
This will give almost 60 Hz, which is close enough for most monitors.
If yours doesn't like it, try 480p60, which gives timings exactly per
spec (though only low resolution). There's work underway to give
correct timings for as many modes as possible, but it won't be ready
for yet a while.
Then type: 'savenv' followed by: 'boot' or simply power cycle.
If you just want to test, "boot" without "saveenv" will work. On the
next boot, the old value will be back.
When using the beagle board hardware check kernel/uboot/etc i get:
All TI u-boots are broken wrt to display timing.
So it would be a solution to use a newer u-boot?
Have also tried the Angstrom flavor of uboot and x-loader as stated above so unfortunately not viable.
So clearly there is some work to be done here in two branches.
First for Angstrom, as noted by Mans, on the fly mode switching is not supported yet via fbset. What are the current issues with getting this to work and relavent source code/maintainer?
Second for the Beagle hardware verification images, what is are the issues with getting it to work and what is the interaction between uboot and the kernel that causes the problem?
I'll start digging through the source code for the beagle code (as its not clear to me yet how to dig through the Angstrom code). Any advice is appreciated and thanks much for everything so far.
How can I change the resolution using Angstrom at all? For example to
800x600 or 640x480 or something like that?
I tried the newest kernel from mansr
(http://git.mansr.com/?p=linux-omap;a=summary) which should contain
the listed patches. My bootargs are:
setenv bootargs console=ttyS2,115200n8 root=/dev/mmcblk0p2 rootdelay=2
rootfstype=ext2 ro video=omapfb:mode:1024x768@60 psplash=false
but instead of 1024x768 I get 1280x720@58Hz and a scrambled display
(fuzzy lines).
I compiled with 'make CROSS_COMPILE=arm-angstrom-linux-gnueabi-
omap3_beagle_defconfig'
(fuzzy lines).
Perhaps I have a wrong config? Does someone has a working
(Framebuffer..) .config for the kernel by mans?
