easiest way to stop u-boot from searching for further uEnv.txt files?
putting together a student lab for building u-boot for the BBB
(which i'll post shortly for anyone who's interested), and just
noticed that when i boot from a minimally-populated SD card (that is,
nothing but MLO and u-boot.ing and an empty uEnv.txt), u-boot still
insists on checking out possible partitions in eMMC, which i *don't*
want it to do.
  here's snippets of the output on the console. first, i can see where
it consults the uEnv.txt file in the VFAT partition, which is
deliberately empty:
... snip ...
mmc0 is current device
Checking for: /uEnv.txt ...
reading uEnv.txt <-- good
0 bytes read in 3 ms (0 Bytes/s)
... snip ...
but further down, u-boot runs off to eMMC and pulls in uEnv.txt files
there as well:
... snip ...
switch to partitions #0, OK
reading uEnv.txt
26 bytes read in 3 ms (7.8 KiB/s) <-- there ...
Importing environment from mmc ...
Checking if uenvcmd is set ...
Checking if client_ip is set ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
33 bytes read in 42 ms (0 Bytes/s) <-- ... and there
... snip ...
  for the purposes of simplicity, i would prefer that u-boot consult
nothing beyond the SD card ... without reconfiguring and rebuilding
u-boot, what is the easiest way to do that? thanks.
rday
(which i’ll post shortly for anyone who’s interested), and just
insists on checking out possible partitions in eMMC, which i don’t
want it to do.
here’s snippets of the output on the console. first, i can see where
deliberately empty:
… snip …
Checking for: /uEnv.txt …
reading uEnv.txt ← good
… snip …
there as well:
… snip …
reading uEnv.txt
26 bytes read in 3 ms (7.8 KiB/s) ← there …
Checking if uenvcmd is set …
Your answer is here: ^
Define uenvcmd to anything and it’ll stop dead.
Checking if client_ip is set …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
33 bytes read in 42 ms (0 Bytes/s) ← … and there
… snip …
nothing beyond the SD card … without reconfiguring and rebuilding
Your best option is just to really rebuild mainline without my patch.
really? i already tried that, all it does is "run uenvcmd", but
unless that command invokes something like a "bootm", processing will
still continue. "bootcmd" has at least a couple places where "uenvcmd"
is run, and bootcmd processing carries on after that.
  i guess another way to ask what i'm after is i want a way to take
eMMC totally out of the boot process in a non-destructive way.
rday
Define uenvcmd to anything and it'll stop dead.
Well yeah, bootm/bootz/etc...
Sorry, i bullet proofed u-boot too much for you..
challenge accepted. :slight_smile:
rday
Oh, also on failure, if you have the usb-slave port connected, eMMC
should pop up as a flash drive. :wink:
